Author Topic: 68 L22 Clone  (Read 13158 times)
HustleRussell
68 L22 Clone
« on: October 11, 2016, 11:29:05 PM »
Got the engine (born in 72 ventura) and transmission (tko 5 speed) bolted together. 96 s10 4 cylinder clutch worked like a charm.
Russ
68 RS
69 SS
HustleRussell
Re: 68 L22 Clone
« Reply #1 on: October 12, 2016, 12:05:52 AM »
Engine and transmission bolted to frame.
Russ
68 RS
69 SS
Re: 68 L22 Clone
« Reply #2 on: October 12, 2016, 12:31:38 AM »
Looking good Russ. Should be a great, fun combo.
68SixBangerRS
  • Camaro Project from HELL
Re: 68 L22 Clone
« Reply #3 on: October 13, 2016, 12:36:28 AM »
I'm glad to see someone has finally cloned a six cylinder Camaro to make up (in a small way) for the thousands of 1st Gen sixes that have been cloned into V8 cars  ::).  Great job, Russ!
MO
Re: 68 L22 Clone
« Reply #4 on: October 13, 2016, 03:44:02 AM »
Very cool. Does the shifter end up in the right place?
HustleRussell
Re: 68 L22 Clone
« Reply #5 on: October 13, 2016, 09:32:21 PM »
  Hard to tell because of floor modifications, but shifter sits towards rear of shifter opening.
Russ
68 RS
69 SS
MO
Re: 68 L22 Clone
« Reply #6 on: October 14, 2016, 03:09:51 AM »
Looks pretty close. Should still be a comfortable fit. Really nice application.
Re: 68 L22 Clone
« Reply #7 on: October 16, 2016, 04:19:35 AM »
What did you source the 5 speed from?
HustleRussell
Re: 68 L22 Clone
« Reply #8 on: October 17, 2016, 01:50:36 AM »
I purchased transmission from summit racing six years ago. Planned on using it in 69 SS. Plans change. After realizing how uncommon MC1 transmission is. I decided to keep 69 original as possible and the 68 gets the 5 speed. 69 is in pieces but that's another story.
Russ
68 RS
69 SS
HustleRussell
Re: 68 L22 Clone
« Reply #9 on: October 17, 2016, 01:56:34 AM »
I also transplanted the 8.5 10 bolt from 72 ventura. Had to shorten driveshaft 3/4".
Russ
68 RS
69 SS
Re: 68 L22 Clone
« Reply #10 on: October 19, 2016, 04:29:32 AM »
OK, that makes sense on the trans.
Why swap rears? Different ratios?
HustleRussell
Re: 68 L22 Clone
« Reply #11 on: October 19, 2016, 11:48:33 PM »
Previous owner had stripped entire drivetrain. He did stick a 3.08 gear, 8.2" Nova rear end back in it, after cutting the spring perches off! So I figured the 3.08 geared 8.5" would be my cheapest easy solution. And if I decide to swap in a 396 at some future time, the stronger rear end is already there. For now I'm building for an economy car. 3.08 gear and 0.64 overdrive equal 1.97 final drive. Hoping that will get some MPG's.
Russ
68 RS
69 SS
HustleRussell
Re: 68 L22 Clone
« Reply #12 on: November 07, 2016, 11:02:18 PM »
Howdy all. Please don't laugh. Update on 68 RS. Drivetrain is fully functional, but car is not road worthy (no brakes). Luckily I have a big yard. So grand daughter rode shot gun on its first drive since 1979!
Russ
68 RS
69 SS
HustleRussell
Re: 68 L22 Clone
« Reply #13 on: November 20, 2016, 12:29:55 AM »
Howdy. Thought I'd share some progress. Not a professional paint. But the family time on the Camaro is priceless.
Russ
68 RS
69 SS
MO
Re: 68 L22 Clone
« Reply #14 on: November 20, 2016, 04:12:48 AM »
Priceless!!
