Teflon Tape!!
Buzz1967:
Hello members!
My question is simple. Was Teflon tape used at the factory? Is it acceptable to use in a restoration that will ultimately be judged?
ko-lek-tor:
You did not explain where or how or what you would use this tape on, but my answer is simple as well:) No, & no,& never use t. tape for anything on a car.
maroman:
Every manual I've read says no teflon tape on fuel lines. The crumbs wind up in the jets or filters.
Z28Project:
I don't think you would ever need it on a fuel fitting since those are all flare type ends. It would only be applicable to tapered pipe type fittings.
John
ko-lek-tor:
--- Quote from: Z28Project on October 11, 2016, 07:39:36 PM ---I don't think you would ever need it on a fuel fitting since those are all flare type ends. It would only be applicable to tapered pipe type fittings.
John
--- End quote ---
True, and plugs are used in oil galleys, Man. trans, rear axles. I may use plumber's pipe dope, but I still would never use T. tape on any car part. Take it for what it's worth, I am only a lowly Farmer/Mechanic with 40 years of A.S.E. certified Master Mechanic credentials.
Navigation
[0] Message Index
[#] Next page
