Author Topic: Early 1968 smog pump  (Read 2679 times)
« on: September 19, 2016, 09:55:39 PM »
Again, not mine, but because not a lot of Camaro guys frequent the Corvette sites, I thought I'd post it here in case you have a 1968  L6, 327, or 350 engine and are looking for a smog pump.
THIS ONE (scroll down to "pump #4) is dated October 17th, 1967 and he only wants $30 plus shipping. It's frozen, but they can be repaired fairly cheaply.
Kelley W King
Re: Early 1968 smog pump
« Reply #1 on: September 20, 2016, 12:49:41 PM »
I read that for a driven car that you just gut them and block the tubes for driveability and show.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
stovebolt
  • 1968 L6 Sport Coupe
« Reply #2 on: September 22, 2016, 12:14:34 PM »
On pump number 4, what does the Z signify? Also, why are date codes sometimes stamped outside of the machined area? I've seen this a few times
« Reply #3 on: September 22, 2016, 01:17:12 PM »
From the EMISSIONS REPORT:
Quote
The last digit is the configuration code of the pump... ...The 68 pumps with a pressure relief valve installed in the pump were coded Y. Non-pressure relief valve 68 pumps were coded Z.
And yes, there are a lot of pumps with the codes stamped on the case NOT in the machined area. Here's a good example of an early 1968 Z28 pump dated 35371Y (December 19th, 1967).
