Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
Attaching Vinyl Top
« previous
next »
Print
Pages: [
1
Author
Topic: Attaching Vinyl Top (Read 3259 times)
Daspots777
Newbie
Attaching Vinyl Top
on:
August 27, 2016, 05:43:17 PM »
I'm having trouble locating the metal pegs/studs, whatever they're called, to attach the trim piece/keeper for my vinyl top. I am missing about half of them and can't seem to find anyone that has any. Thanks!
Tweet
Logged
Hero Member
Re: Attaching Vinyl Top
Reply #1 on:
August 28, 2016, 04:16:13 PM »
Eastwood (among others) sells the stud guns and trim rivets for attaching trim like the factory did with a welded stud. Used the same for window trim clips -
You can buy the rivets as replacements from them, and/or buy the whole system. Comparatively easy to handle - see the website link below that shows the stud detail (with the approximate clip in the pic).
http://www.eastwood.com/stud-welder-trim-rivet-tip.html
Logged
1969 Z11 L48/M35/C60/C06 1949 3100 5wd 235/6
ban617
Member
Reply #2 on:
August 30, 2016, 05:43:12 AM »
If your car is already painted , you should be able to get ones that screw in just drill a small hole & screw them in ... Most body shop supply places have them or can get them ...
Logged
Daspots777
Newbie
Reply #3 on:
August 31, 2016, 01:28:39 AM »
Excellent, that gives me somewhere to start.
Thanks to both of you!
Logged
69 Zee
Hero Member
Reply #4 on:
September 09, 2016, 12:36:18 AM »
Here's a previous thread by HawkX66 (Dave) another member. Discussing the stud placements as well as a stud gun tip (home made).
http://www.camaros.org/forum/index.php?topic=13894.msg120737#msg120737
Also just for future reference, try using the search window at the bottom right of CRG's home page (showing the 3 Camaro's) as an overall search. Or in the forum section each "Group Discussion Topic" will also have a search window at the top right.
Ex..discussion forum "Originality", type Vinyl top rivet
Hope this helps
Logged
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
Print
Pages: [
1
« previous
next »
Restoration
Attaching Vinyl Top
