Author Topic: Where does this clip go?  (Read 5618 times)
BillOhio
    • photobucket
« on: July 08, 2016, 04:54:24 PM »
I have a few parts left over and found these clips in a bag marked door panels. Looks like a left and right version. I even searched the hbc website and no luck. Anyone know what they are?
1968 RS 327 4 speed
Re: Where does this clip go?
« Reply #1 on: July 08, 2016, 04:56:02 PM »
They look familiar..  Is it the door panel clips??
Edit: nevermind thats not it..
69z27z87
  • The garage - my happy place
« Reply #2 on: July 08, 2016, 05:08:48 PM »
That looks like the clip that holds the windlace trim in place...the one end goes over the welded door seam and clamps on
1969 SS396 - L35, Z87 Daytona Yellow, Yellow Houndstooth, Black Vinyl top
1992 Z28 - LB9 Purple Haze, T-5WC, grey leather interior
BillOhio
    • photobucket
« Reply #3 on: July 08, 2016, 05:15:52 PM »
Interesting it has a hole like you could put a screw in it. At least windlace I can still get to
1968 RS 327 4 speed
BillOhio
    • photobucket
« Reply #4 on: July 08, 2016, 05:26:45 PM »
I think we have a winner. This is from the HBC website. I do not remember seeing a place for a screw to go though. Thanks guys
1968 RS 327 4 speed
« Reply #5 on: July 08, 2016, 05:36:50 PM »
My windlace uses the screw.
HawkX66
« Reply #6 on: July 08, 2016, 06:26:19 PM »
That's it. Right at the top of the door frame above the door striker.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #7 on: July 08, 2016, 09:04:13 PM »
A very small phosphate phillips screw goes in that lace holder.
KevinW
« Reply #8 on: July 09, 2016, 11:08:49 AM »
Yup, upper windlace holder. The tab with the screw hole actually goes BEHIND the qtr window fuzzy (between fuzzy and sheet metal).  The small screw that holds the qtr fuzzy holds the windlace bracket too.
BillOhio
    • photobucket
« Reply #9 on: July 09, 2016, 08:06:35 PM »
Ok i looked and didn't see a hole. Might not mess with it!
1968 RS 327 4 speed
« Reply #10 on: July 09, 2016, 08:54:53 PM »
X2! The staples hold the fuzzy and so does the screw in a sense but the main goal of the screw is to hold the lace. Bill, you might not be seeing the hole due to the fuzzy covering it as Kevin mentioned it goes behind. I'd put it in if at all possible!
Stingr69
« Reply #11 on: July 11, 2016, 01:11:59 PM »
Commonly trashed when the windlace is ripped out by a heavy hand.  I paid quite a lot to get some serviceable used replacement windlace years ago.  Very necessary and I do not think they are reproduced properly.
