Author Topic: Unpublished: 1967 Z28 Detailed Production Numbers  (Read 13555 times)
fsc66
Re: Unpublished: 1967 Z28 Detailed Production Numbers
« Reply #15 on: July 11, 2016, 12:49:19 AM »
I checked on the combined Z28/RS data for 69, nothing , in fact they list less ECL codes in 69 and just show a number for total ECL's and total units produced for many options.
« Reply #16 on: July 11, 2016, 01:02:02 AM »
Quote
Well, under L89 there is only 1 ECL code and it lists 272 Units. It states, used with L78 and L78 shows
4 ECL codes with no usage data.
Thanks Paul. I'd LOVE to know where the old USCC came up with their numbers!
« Reply #17 on: July 11, 2016, 01:12:18 AM »
How many L89 cars have been confirmed & recorded for 68?
« Reply #18 on: July 11, 2016, 01:19:19 AM »
Quote
There's around 10 if I remember correctly. Of those, I believe 3 are Convertibles.
« Reply #19 on: July 11, 2016, 01:26:00 AM »
Is yours one of the 3 or 10?  Did it have original docs or engine?  Sorry for all the questions but I would like to add it to my database/registry.
« Reply #20 on: July 11, 2016, 01:36:17 AM »
I didn't even know you were building a data base.... ;D
« Reply #21 on: July 11, 2016, 01:41:36 AM »
Because you are not interested in 68 L78/89 cars..   ;)
« Reply #22 on: July 11, 2016, 01:47:57 AM »
Quote
No, not any. I have no docs and the original block is gone.
« Reply #23 on: July 11, 2016, 01:48:26 AM »
It's from an unpublished trend book that was shared only with a few GM Execs. I believe one of those Retired Execs last year sold a copy and now a few others have that information. Pretty sure NCRS has it all, but no one is sharing any of the information for the most part.
Yes I have that data for 68's', The 69 Camaro information is only through the end of August so it was not final data.
The Book encompasses all Chevrolet Models dating back to the mid 50's through 1969. There is limited 1970 information through only March.
The biggest issue is that often times the ECL codes are listed with individual production information but there is no usage column stating when that ECL code was used
As an example, 1968 Camaro under Z22  lists in parenthesis 108 ECL codes with 40,977 units produced. No listing of each ECL code. Under ZJ9 there's only 4 ECL codes, each is listed with production on each ECL but no explanation of when they are used. I think you understand.
Paul, since you have the data for 68's can you list it for us as you did for 67's? I'd love to have for my 68 Z/28 information.
thanks in advance,
wtexz10
« Reply #24 on: July 11, 2016, 09:59:09 PM »
Anything on Z10's?
69 Camaro Z10.. 72 GMC C1500
79 Mazda RX7.. 79 Trans Am WS6
06 Corvette Z06.. 10 BMW 650i
fsc66
« Reply #25 on: July 11, 2016, 11:20:21 PM »
Nope, options only. If an engine was a way to identify a model and that engine was specific to the that model or perhaps an option that was specific to only Z10's there may be a work around that way.
Paul Winvoices
« Reply #26 on: July 12, 2016, 05:03:47 AM »
Z10 was an option in 69, same as Z11. Both required other options (RS, SS, etc).
fsc66
« Reply #27 on: July 12, 2016, 09:54:03 AM »
Well perhaps GM thought of those as non-standard models because they do have the Z28, Z22, but no Z10 or Z11 and they also don't list the COPO #'s......although they do have some stranger COPO items listed like for 69: ZV7: COPO Transmission M21 or ZP1 C.O.P.O Tires but no 9511, 9560, etc.
Strange......
