Author Topic: Installation Trunk Lid Emblem  (Read 18095 times)
69 Zee
Re: Installation Trunk Lid Emblem
« Reply #15 on: June 08, 2016, 02:13:56 PM »
The "Camaro" script and the "By Chevrolet" block lettering was different though they look very very similar unless put side by side.
There was a difference in the positioning of the location pins as well.   I'll dig mine out and post pics.
With today's reproduction,  I strongly doubt that each one of these emblems are being reproduced as two separate emblems.  Since they look similar (to most) it's just cost effective to produce one design to use in both places, the header and deck lid.
Another reason to "measure twice" and cut once.  If your using the reproduction emblem of p/n 3916654 and your not shooting for factory correct then use.  But I'd suggest to pick one point on deck lid, then caliper the pins of the new emblem at center-to-center or as stated earlier, use a lipstick of sort and plot on paper. Use as a template.
Or you can find the factory 'Fisher Body" emblems on ebay. I see them all the time from $15 to $25.
Pick your poison...lol
« Last Edit: June 08, 2016, 03:23:01 PM by 69 Zee »
Darrell
jack
  • 69 camaro SS
« Reply #16 on: June 08, 2016, 07:59:18 PM »
I am trying to restore the car Correct. Its a matching numbers car.
Please show me pics if possible. I will try to hunt down a NOS 7752901. On the web (for sale) they say a rear nos emblem is 3916654.
Jack
69 Zee
« Reply #17 on: June 08, 2016, 08:59:10 PM »
About a yr ago I noticed my Z/28 emblems for the fenders, grille and tail panel had similar p/n markings.  During I found another thread on CRG on these emblems as well (been to busy to search, sorry).  I believe John Z had mentioned in that thread that the deck lid emblem was a Fisher Body installation (reason it's not in the AIM).
John please forgive me if it wasn't you as my memory may of lapsed...ugh !
That drew my attention to mine header and deck lid emblems as I was bagging and tagging.  My emblem p/n's are exactly as those mentioned before and they are original to the car.
NOW...my car is a Norwood 03B date trim tag.  I'm only stating this because anything seemed possible during these builds and I don't want you or anyone else locked in on what I'm saying.
Did GM and Fisher Body install these emblems with different p/n's thru the entire building process ?  Or could there of been a time that one Division could of ran short thus grabbing some from the other ?  Which would put two emblems of the same p/n on the same car....Maybe John Z can chime in.
Looking at the backs, notice the casting of the scripted lettering.  There's more recessed cavity area on the deck lid (bottom pic) vs the header emblem (top pic)
Darrell
69 Zee
« Reply #18 on: June 08, 2016, 09:19:33 PM »
Yes, since the backs are fastened to the car and nobody can see them why produce two different emblems that look virtually the same.  Also, what sells in reproduction parts ?  a GM p/n or a Fisher Body p/n?
Remember, Fisher Body installed and completed most to these shell from the firewall back.  This included trim molding, glass, doors, deck lid, emblems, hardware and some wiring among a few other things.
Darrell
jack
  • 69 camaro SS
« Reply #19 on: June 11, 2016, 03:00:55 AM »
Thanks Darrell
You have been a great help..
Jack
« Reply #20 on: June 11, 2016, 12:07:54 PM »
What is the difference between 3916654 and 7752901?
Jack
To my understanding:
Dimensionally, these 2 emblems are the same. The reason for 2 part numbers is that the trunk one had sealer (black rubber like)  inside the speed nuts to seal water out of the trunk interior. The header, of course, did not have, nor needed sealer.
69 Zee
« Reply #21 on: June 11, 2016, 01:32:51 PM »
Thanks Bentley, you are correct.  I failed to correct that previous statement.  The 2 are identical in dimensions.
Darrell
zman1969
« Reply #22 on: July 18, 2016, 02:04:37 PM »
well this thread has great information in it! and I am interested in installing the emblem on my car soon and it is a spoiler car, would anyone care to post up the measurements for a spoiler car and kind of complete the thread - with and without spoilers? thanks All!
Rich
69 RS/Z DZ302 Daytona bumble bee
69 T/A clone LS6/6sp
69 Nova SS 396
« Reply #23 on: July 22, 2016, 02:55:44 AM »
That would not cause two different emblem part numbers. The emblems would be the same and just the speed nuts would be different.
Even if the supplier put sealer on the emblem, the assembly would different but the emblems would be the same #.
