Author Topic: 1969 Zl1 Intake Casting Number Question  (Read 3411 times)
69z28rsbilly
« on: May 03, 2016, 05:22:46 PM »
Did the early 1969 Zl1 Camaro Intakes have casting numbers ?
As I have seen a lot of early "198"Factory Winters dated 1968 BBC open divider intakes with no casting number or the last three digits factory ground down and hand stamped 198, and some with a raised boss for the casting number but left blank.....
I was thinking of buying one without no casting mark but dated late 1968....
Thanks in advance....
X33 72 72 RS
X33 71 71 RS
X33 10 10
Re: 1969 Zl1 Intake Casting Number Question
« Reply #1 on: May 04, 2016, 02:32:46 PM »
The only builds that fit the "early" category would be #1 & #2 final-assembled December 30, 1968. Both had pilot engines built at Flint late November. It is possible they had hand-stamped intake manifolds.
69z28rsbilly
« Reply #2 on: May 08, 2016, 02:38:05 AM »
Thanks William
 Did the first two 69 ZL1 pilot engines have the casting number( or a number) cast in to the block(between the two ribs) above the timing chain cover ?
thanks
X33 72 72 RS
X33 71 71 RS
X33 10 10
« Reply #3 on: May 10, 2016, 03:44:27 PM »
Only the block from #1 still exists. It is no different than the other known production ZL1 engines.
69z28rsbilly
« Reply #4 on: May 18, 2016, 02:09:07 AM »
X33 72 72 RS
X33 71 71 RS
X33 10 10
