Author Topic: Hurst Shifter date codes  (Read 22273 times)
Re: Hurst Shifter date codes
« Reply #30 on: April 12, 2016, 01:52:01 PM »
The date Code on my shifter is 19D51J from a 02A Z/28
LOS or NOR ???  If you can, try to make pic a little smaller next time.  Thanks!
1967 RS/SS 396 coupe L35/M40 - 4 generation family project
jdv69z
  • 69 RS Z/28 52E
« Reply #31 on: April 13, 2016, 01:15:21 PM »
So attached is a pic of the Hurst shifter from my 69 Z, build 10B, Oct 68. Shifter is dated  6  8B2. The 6 is hard to see. I'm not sure this one is on the list? Sorry if duplication.
Jimmy V.
« Reply #32 on: April 13, 2016, 04:05:38 PM »
Thanks Jimmy V. I had copied your data over from the shifter report thread earlier.
JoeC
« Reply #33 on: April 14, 2016, 03:09:20 PM »
here are pics of my 78D2
looks original but has some surface rust
so far it looks like 88D3 is the latest 4 digit code and 108D41C is the earliest 6-7 digit code ?
« Reply #34 on: April 14, 2016, 03:23:10 PM »
We haven't been keeping up with it, but are all these '69 Shifter bodies marked '3138', whether early or later ??  Or did they change the model number along with the mfg code  in the September '68 timeframe??
suturb110
« Reply #35 on: April 14, 2016, 06:35:08 PM »
My 88D3 date coded shifter also has 3138 stamped on the front of the shifter body.
« Reply #36 on: April 14, 2016, 07:48:12 PM »
Most if not all should be 3138 bodies.
« Reply #37 on: April 15, 2016, 04:31:10 AM »
I also asked the 69 Firebird guys about shifters. Nothing yet.
jdv69z
  • 69 RS Z/28 52E
« Reply #38 on: April 15, 2016, 12:47:10 PM »
So where's the 3138 stamping? On the front if I'm under the car looking front to rear?
Jimmy V.
suturb110
« Reply #39 on: April 15, 2016, 03:22:09 PM »
yes on the front on the shifter.
JoeC
« Reply #40 on: April 15, 2016, 04:52:45 PM »
3138 is the Hurst part number just for that stamped part that makes up the outside case
It was used on many OEM shifters (Camaro Firebird GTO and others)
Hans L
« Reply #41 on: April 25, 2016, 04:29:25 AM »
Here you go - '69 Z, 04B VN, M22 trans:   9D53D
http://www.littooy.com/hans/
'69 Chevelle SS 396 4 Speed
« Reply #42 on: April 25, 2016, 07:02:09 AM »
Hans - Can you check to see if there is another digit before the 9 please? It may be very lightly stamped.  Thanks!
ZLP955
« Reply #43 on: April 25, 2016, 10:07:59 AM »
Is that a faint '1' before the 9D53D?
Tim in Australia.
1969 04A Van Nuys Z/28. Cortez Silver, Dark Blue interior, VE3 bumper, Z21, Z23, D55/U17, D80, flat hood.
Sold at Clippinger Chevrolet in Covina, CA. Ex-Racer at Lions Dragstrip in Long Beach.
Hans L
« Reply #44 on: April 25, 2016, 03:03:25 PM »
Will do.   I'll have to crawl under and see now.  The shifter is on the car....but when I blew up the pic above, there does indeed seem to be a faint 1 before the 9...
