Author Topic: Original engine emblem paint color for '69  (Read 4113 times)
makeminea69
« on: March 07, 2016, 02:33:38 AM »
Can anyone help me with the correct fender emblem colors?  I ordered fender and engine emblems for a '69 SS 396.  The SS had white paint, the 396 was an off-white color.  Is this correct?  I was thinking they should both be white.
Re: Original engine emblem paint color for '69
« Reply #1 on: March 07, 2016, 06:13:58 AM »
The color is not a pure white, it is slightly off white- I used an eggshell color semigloss. First stripped all the old paint using stripper then I taped them, cut the recesses with a brand new exacto and sprayed them.
Plackard emblems like SS tail panel or grille emblems spray the white first then tape all then spray the satin or semi black.
makeminea69
« Reply #2 on: March 07, 2016, 01:11:01 PM »
Apparently I have the ones I need then.  Thanks for the reply and the pics!
VINCE Z28
« Reply #3 on: March 07, 2016, 01:16:30 PM »
James did you use a can, and how many coats of paint?
« Reply #4 on: March 07, 2016, 02:25:08 PM »
Yes rattle can, just enough to cover, 1 wet coat.
I soaked the emblems in EVAPORUST after stripping with chemical stripper, they look 100% better than when removed.
The reproduction SS emblems and 396 emblems look like the characters are over inflated, they appear soft, bulging in the middle.
makeminea69
« Reply #5 on: March 19, 2016, 12:43:17 AM »
James, one last question.  Did you use the same color for the SS and the 396 emblem?
« Reply #6 on: March 20, 2016, 12:50:17 AM »
Yes I did I used it on both, I bought a stark white Toyota color and Krylon Satin white 2 in 1 primer paint used a tooth pick to put a drop in the CUI and SS emblems...the stark white appeared "brighter" the satin Krylon looked to match.
KRYLON 2 in 1 primer paint -  Satin White which appears to be a slight off white.
2 light coats or one full coverage -
I tried 2 full coverage coats and had to strip the paint out.. it looked like it was poured in...
makeminea69
« Reply #7 on: June 26, 2016, 03:08:26 AM »
James, when I sent this original question my car was off being painted and the bodyshop had the emblems with it.  Now that it is back, I realized I had the emblem colors switched.  So, again, I ordered both the engine and SS emblems.  The paint on the engine emblems appears whiter and the SS emblems appear to have an off-white color.  The car is Daytona Yellow.  Is this color correct for the SS emblems?  I've tried to attach a pic of an S next to the engine emblem to give you an idea of what I am talking about.
