Author Topic: driveshaft - de-rusting and rustproofing  (Read 14475 times)
69z27z87
  • The garage - my happy place
« on: February 25, 2016, 05:52:54 PM »
After degreasing my driveshaft to find the color bands (thanks leaky rear main), I want to de-rust it to return to the "natural" look it started with. I tried using Evap-rust soaked papertowels wrapped in plastic... some progress. Any one find anything better?
How do you keep the driveshaft looking "natural" after de-rusting?.. same with the yokes... hope to retain this nice look...
1969 SS396 - L35, Z87 Daytona Yellow, Yellow Houndstooth, Black Vinyl top
1992 Z28 - LB9 Purple Haze, T-5WC, grey leather interior
Re: driveshaft - de-rusting and rustproofing
« Reply #1 on: February 25, 2016, 06:05:56 PM »
Go to lowes or Home Depot & get a 4" piece of PVC and a cap for said pipe.  Cut to desired length & cap one end.  Slide driveshaft into PVC pipe and fill will approximately 2 gal of evapo.  I used a long screwdriver and vise grips to keep it submerged as it will float.  Pull every couple of hours and wipe down and resubmerge. Keep doing this until clean.
Caution - stripes on shaft will more than likely lift off and disappear so take excellent pics before hand that way you can duplicate it afterward.  I have used a satin clear on my blue car and on the green car I'm using Cosmoline Rust Veto in aerosol form.  Chick (68camaroz28) has this in his build thread over on TC.
69z27z87
« Reply #2 on: February 26, 2016, 12:31:46 AM »
I like it.... Got the pipe, need the end cap....just gotta decide how to protect....
Has anyone had to rebalance the driveshaft after all this fiddling?
« Reply #3 on: February 26, 2016, 12:38:12 AM »
I havent..
« Reply #4 on: February 26, 2016, 05:14:34 AM »
Re-balancing should only be necessary if the crud/rust/dirt was used in achieving the original driveshaft balance..  :)
« Reply #5 on: February 26, 2016, 06:22:15 PM »
Put the driveshaft in the tube first and then add the 2gallons with yoke going in tube first. I had a lot of paint on my yoke along with stripes. Check as Darrell mentioned but do not wipe over areas that may have paint. Have fun! Five foot piece works well.
« Reply #6 on: February 26, 2016, 07:26:34 PM »
 Clear coat I can see not being a problem, but with a spray on preservative I would think between heat and centrifugal force that the coating would quickly fling off the spinning shaft and eventually cause a film build in the tunnel.
69z27z87
« Reply #7 on: February 29, 2016, 05:41:59 PM »
so I built my dip tank and added 1 gallon of evapo-rust.... I must say that these chemicals really are a nice piece of an evolving technology....
Now I just have to flip the shaft over and dunk the other end....
And I am going to add a Matte clear finish.
« Reply #8 on: February 29, 2016, 05:49:33 PM »
Anytime I've used evaporust (or metal rescue) and only submerged 1/2 of the part at a time, it's resulted in a slightly different color in the two halves and a visible 'line' separating the two halves...
1968 Z28
« Reply #9 on: February 29, 2016, 06:11:07 PM »
X2.....Yup....I agree.  I always submerge  the entire piece to be derusted for that very reason.  If you plan on painting the piece the "line" wouldn't be a problem, but if you want to have the same color over the entire piece then total submersion is the only way to do that.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #10 on: February 29, 2016, 07:57:34 PM »
X3
« Reply #11 on: March 02, 2016, 12:39:46 AM »
X4 Learned long ago not a great idea!
sixt9x33rs
« Reply #12 on: March 02, 2016, 12:06:49 PM »
I used a long piece of plumbing pipe so I could dip the entire driveshaft. You may want to get a longer piece of pipe?
69z27z87
« Reply #13 on: March 02, 2016, 05:53:31 PM »
I had long enough pipe... just not enough evaporust... bought the last gallon the store had...
that said.. I am not disappointed...looks a lot better than what I started with.... and no one is ever going to see it once the car is on the road... but that's me.
big iron
« Reply #14 on: March 10, 2016, 09:11:36 PM »
I want to do my 67 T400 shaft but I want to do the shaft with U joints and transmission yoke installed. The U joints are in perfect condition and do not want to destroy plastic injection used to secure the U joints by taking them apart. Do you think this process will harm the U joints?
Bob
