Author Topic: location of 12bolt axle stamps  (Read 8727 times)
aaronz28
« on: February 04, 2016, 01:32:46 PM »
quick question -  i've seen 3-4 Camaro/Nova 12bolts in my day and the stamps always seemed to be on the pass side tube facing forward.... (at least that is my memory at the moment)
were the axle stamps ALWAYS in the same place? I suspect because its probably more accessible when the transverse muffler is hanging in place - - or was it stamped prior to assembly, and just the way it was - or is just odds that the ones I've looked at all are in the same place?
Re: location of 12bolt axle stamps
« Reply #1 on: February 04, 2016, 02:02:42 PM »
The axles were stamped in the plant where the axles were fabricated/assembled, NOT in the Camaro assembly plant!   Yes, I think all the GM axles (in that time period) were stamped identically.
« Last Edit: February 04, 2016, 02:35:26 PM by 69Z28-RS »
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: February 04, 2016, 02:03:13 PM »
I would think the stamping was done at the axle plant.
Jimmy V.
« Reply #3 on: February 04, 2016, 02:58:23 PM »
The date stamping was done at the axle plants and it is the date the unit was assembled. There is also a casting date on the center section.
In the mid/late 60s and early 70s, Chevrolet axles were in the same location. I can't say for sure if other GM divisions always followed that. They may have, I just can't say for sure.
« Reply #4 on: February 04, 2016, 10:47:29 PM »
Pretty sure Pontiac Firebirds and GTOs had it in the same location as Chevrolet.
rare396bronze
« Reply #5 on: February 05, 2016, 02:40:20 AM »
GM still does up to now.
« Reply #6 on: February 05, 2016, 07:54:34 AM »
I believe Firebirds were diagonally opposite - driver's side rear. And only the application code, no date.
« Reply #7 on: February 05, 2016, 08:19:50 AM »
Correct.
« Reply #8 on: February 05, 2016, 11:59:09 PM »
OK, you made me look it up. No more relying on memory. :)
First Gen Firebird codes were as you say, on the drivers side axle tube.
http://firstgenfirebird.org/f-a-q/axle-code-facts/
I have been under way too many A body GM cars, probably over a thousand. GTOs, Chevelles, Skylarks...
The Chevrolet data I posted above I believe is correct.  I guess the best thing would be to search for a site for a particular model because I know at some point Firebird axle codes went to the passenger side and GTOs changed from one side to the other depending on year.
aaronz28
« Reply #9 on: February 06, 2016, 12:01:42 AM »
I'm specifically looking for a 12bolt Camaro housing with 3.73, 4.10, or 4.56
last week of august, or 1st week of sept.
thanks
« Reply #10 on: February 06, 2016, 12:13:07 AM »
All first generation Camaro rear axle codes were stamped in the area illustrated below...
« Reply #11 on: February 06, 2016, 01:07:47 AM »
thanks
What year?
Never mind I went back to your other thread about parts you are looking for. Car is 09D of 1969.
You may find a 3.73 but 4.10 will be tougher and 4.56 extremely hard to find that date in my opinion.
jacmac
« Reply #12 on: February 06, 2016, 01:29:34 AM »
My friend has a 71 Trans Am that we restored & axle code is on the front pass side
69 Z10,69 ss396Chevelle, 71 Corvette
