Author Topic: 1969 Z/28 Stripe Widths and Gaps?  (Read 21692 times)
Prackman
« on: December 05, 2015, 04:02:36 PM »
This question may have been addressed in an older thread but I can not located it, so I need to ask again.
Looking at the AIM for 1969, pages 474 & 475 indicates that the outer (pin) stripe, Z28 option, is .25 inch wide and has a .38 inch gap between the pin and larger rallye stripe.
However, in Jerry MacNiesh's 1969 Camaro Z/28 fact book (2nd Edition, page 74), Jerry states that both the pin stripe width and gap width are equal at 9/32 (.28125) inches.
Questions:
 - which is correct?
 - did the Norwood and Van Nuys plants have different paint standards for these stripes?
 - did Fisher body or Chevrolet perform the painting process?
John
1969 Z/28 VN Built
1967 SS
Re: 1969 Z/28 Stripe Widths and Gaps?
« Reply #1 on: December 05, 2015, 05:37:29 PM »
I'm sure the AIM has the more accurate specification, but in application of the spec, perhaps Jerry's measures are indicative of how they come out of paint.  I'm sure the factory didn't measure/check/correct to see that they matched the AIM spec..  if they looked good...  they car was OK'ed and shipped...  :)    Or maybe JohnZ will tell us that they did check the stripe/spacing  against some 'wider' spec before approval??
PS.  My car has original paint from the firewall back, so I could check the rear deck stripes and take some photos with a precision ruler alongside if that would help..  :)
Prackman
« Reply #2 on: December 05, 2015, 05:43:29 PM »
Gary W - any photo's would be greatly appreciated.  It seems all the vehicles I currently see painted with Rallye stripes have a gap distance = pin stripe width.
John
1969 Z/28 VN Built
1967 SS
6667ss138
« Reply #3 on: December 05, 2015, 06:53:20 PM »
I just measured my original paint stripes on my hood and rear spoiler. It looks to me like the distance between is mostly the same.  I will post pictures later and let you be the judge.
ZLP955
« Reply #4 on: December 05, 2015, 10:12:41 PM »
On my LOS car, the pinstripe and gap are equal, and the overall width of both is 9/16". I made a drawing of the stripe measurements a few years ago, I'd be happy to share it with you if required but it does differ from the AIM specs and so is only really a record of how this car was done.
Tim in Australia.
X33RS
« Reply #5 on: December 05, 2015, 10:45:26 PM »
There is enough of the original stripes left on mine to measure both front and back, I just haven't gotten to that point with the car yet.  It's a 12D Norwood car, if that helps you at all I'll measure it.
But I'm willing to bet that you might find mild variances depending on plant and time frame at that specific plant which probably explains why Jerry sees one thing and the AIM states another.  Something like this is not uncommon at all.  If you want to be technically correct it would be best to find an original example from the same plant that is at least within a couple weeks of your build.  Because I highly doubt that all stripes measured exactly the same between 20,302 69 Z28's built at 2 different plants.
6667ss138
« Reply #6 on: December 05, 2015, 11:22:29 PM »
Hood pics. Hope this helps. Let me know if you need more pics and or measurments.
6667ss138
« Reply #7 on: December 05, 2015, 11:24:40 PM »
Rear spoiler.
Prackman
« Reply #8 on: December 06, 2015, 02:21:36 AM »
Thanks Len - your dimensions confirms Jerry's and what I generally see out there.  Still wonder why the AIM has such a discrepancy.
Thanks again
John
John
1969 Z/28 VN Built
1967 SS
« Reply #9 on: December 06, 2015, 02:26:37 AM »
John,  I see something different than you apparently....  it must be in the 'eyes of the beholder'...  If you are 'painting your car', then I'd suggest going by the AIM... then see what you have after the tape is removed.
Gary
« Reply #10 on: December 06, 2015, 06:28:56 AM »
The AIM has a known error in the stripe dimensions. I don't recall which dimension, but Mark C will. :)
ZLP955
« Reply #11 on: December 06, 2015, 08:31:52 AM »
There's definitely an error in the '69 AIM for the distance the rear stripes should stop from the rear glass trim, can't recall the dimensions off the top of my head but I think the conflicting measurement arose from the difference between v-top and no v-top.
Tim in Australia.
Mark
« Reply #12 on: December 06, 2015, 01:15:13 PM »
Generally the stripe gap and pin stripe dimensions are both the same and they each measure 9/32".  My pacecar original stripes were 1/4" gap and 3/8" pin stripe.  Seams the stripes changed and it appears to be random (ie not before or after a certain date), may have something to do with the masking tape available at the time the car was built.  LA cars are different than Nopwood built cars, they seem to follow the AIM more closely.   Note that the right rear stripe is about 5/16" wider than the left rear stripe.  The Camaro emblem has to be completely in the main body of the stripe, and it won't be if you use the AIM dimensions, it will end up in the gap between the main and pin stripe.  Top of the rear stripe is 5/8" from the rear window, convertible well trim, or vinyl top trim.  Front stripes are not the same width front to back either.  Then are narrower at the front than the rear by about 1/4" so the appear straight when looked at from the front of the car.  Center edges of the front stripes are parallel and evenly spaced front to rear.
Check out this thread over at Camaros.net and all the links in it, that should answer about 99 percent of your questions on Rally Stripes.
http://www.camaros.net/forums/showthread.php?t=303841
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
X33RS
« Reply #13 on: December 06, 2015, 03:10:30 PM »
Lol, they seem to be all over the place, when you read that it goes back and forth.  I'll have to go back and read that again but I'm not so sure they even came to an agreement as to when the narrow rear stripe on 69's went away and the wide rear stripe was phased in.
For what it's worth, the original rear stripes on my 12D 69 are the wide ones.   This is a no spoiler car which may have made a difference because from what I understand from reading that, if mine were to have a rear spoiler it would be the 68 variety and also have narrow rear stripes, however the original stripes on my car are definitely wide.  Maybe being no spoiler had something to do with that.
« Reply #14 on: December 06, 2015, 04:00:12 PM »
Mark is correct. My X77 measured exactly 9/32 gap, found this out when I painted the hood in '75. I masked the stripes out by hand as there were no stencils reproduced in those days -
