Author Topic: Spiral Shocks  (Read 24181 times)
Pex68
Spiral Shocks
« on: November 16, 2005, 03:30:51 AM »
Originally posted this in Team Camaro but never got a definitive answer so I thought I would try here.
Curious if someone knows the correct original part numbers for the shocks that would have come on a 68 SS 396/325 with a M20? I have been finding different info in all my books and manuals. Thinking 3192477 & 3192851 but have found some sources saying 3192826 & 3192831??? What Gives??? Please help!!!!
Also, I know when you ordered the SS you got what's referred to in books as a "special suspension" with the SS package. Am I correct in assuming that was the F41 package and if so did the shocks follow that or still varied with other options i.e. AC/engine/whatever?
Thanks!!!
Chris P
copo
Re: Spiral Shocks
« Reply #1 on: November 16, 2005, 05:16:06 AM »
The correct spiral shocks for your B/B are 319477 and 3192851. The 3192826 and 3192831 are for the base car with rear mono leaf springs. The rear shock # 3192851 on the multi leaf springs uses lower mounting stud and the mono rear shock # 3192831 use a nut and bolt for mounting to lower spring plate.
Pex68
Re: Spiral Shocks
« Reply #2 on: November 16, 2005, 02:49:11 PM »
Ok, so 477 & 851, and am I correct in thinking the 477 has a broadcast code of PS for 68 and 851 has UN?
Any takers on the SS suspension being same as F41 question???
Chris P
Pex68
Re: Spiral Shocks
« Reply #3 on: November 20, 2005, 07:48:42 AM »
WOW, thought I'd get more responses here, at least I don't feel so stupid not knowing the difference between the SS and F41 suspension, thought someone would though.  ??? :o ;D
Chris P
Mark
Re: Spiral Shocks
« Reply #4 on: November 20, 2005, 11:26:03 PM »
1968 L35 equipped Camaro shock broadcast codes are PW front, TN rear.  PS and UN are 69 Z28 shock broadcast codes.
« Last Edit: November 20, 2005, 11:29:30 PM by Mark »
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Pex68
Re: Spiral Shocks
« Reply #5 on: November 21, 2005, 02:19:24 AM »
Mark,
Just want to be sure that's correct, according to the Camaro restoration guide, page 114 states 477 is PS for 67-69 and PW for 69 only (that's were the confusion comes in) and 851 is UN for 68 only.  TN is listed as 3192832 for 68 4spd w/o F41 & 69 L34, L35, L72, L78, L89.  This is why I am having so much trouble locking this down, I can't find anything that states the applications clearly.  Just curious, where are you getting your info from?
Thanks, Chris.
Chris P
Mark
Re: Spiral Shocks
« Reply #6 on: November 21, 2005, 03:15:00 AM »
Off a 68 L35 big block chassis broadcast sheet and a 69 Z28 chassis broadcast sheet.  Front shocks in 68 are the same in both a 327/275 and the L35, but different shocks were used in 6 cylinder cars.
« Last Edit: November 21, 2005, 03:18:59 AM by Mark »
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Pex68
Re: Spiral Shocks
« Reply #7 on: November 21, 2005, 03:21:21 AM »
Now I'm really confused ???  Thanks for the info.
Chris P
Mark
Re: Spiral Shocks
« Reply #8 on: November 21, 2005, 11:53:35 AM »
Out of all the 68 broadcast sheets I have this is what I've found.
from body broadcast sheets
Late production L30/M20 with A/C Rear shock UN. (BBC)
L30/M20 rear shock UN (BBC)
L35/M40 rear shock TN (BBC)
Z28/M20 rear shock UN (BBC)
From chassis broadcast sheets
68 L35 front PW, rear TN - front springs are YQ rear are OH.
68 L22 L6 with powerglide front TG rear, TN - front springs are YL rear are BV.
68 L35 with TH400 trans, front PW, rear TN - front springs are YQ and rear are OH.
67 LF7 powerglide front LG, rear LH - front springs are YU rear are BX.
67 LF7 powerglide with A/c front LG, rear LH - front springs are YY, rear are YC.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Tinkerr
Re: Spiral Shocks
« Reply #9 on: November 21, 2005, 07:40:42 PM »
Mark,
I don't know if you helped Chris,but you solved a dilemma for me and created another.My front springs(68rsss396) had the YQ tag still attached,but I couldn't find any referrence to that code in the parts manuals.I thought somebody my have swapped them years ago.
My Camaro resto guide refers that YQ tag to 327/350's although I know you need to crosscheck his info. where do you buy new spring tags?Thanks Paul
Pex68
Re: Spiral Shocks
« Reply #10 on: November 22, 2005, 03:24:07 AM »
Paul,
In digging deeper into my books it looks like any combination of spring/shock "could" have come on any given car based on WEIGHT with the chosen options.  I'm sure there was some basic standard but we all know nothing was set in stone with these cars.  Do the tags look original?  If they do I wouldn't mess with them, otherwise you can get them at any of the vendors, try Kenny at www.SS396.com or Ricks www.firstgen.com
Mark, you did help, THANKS!!!
Chris.
Chris P
Tinkerr
Re: Spiral Shocks
« Reply #11 on: November 22, 2005, 07:36:31 AM »
Chris
I'm attempting a full nut & bolt resto hence the springs need to be sandblasted or replaced.The tags would never survive that besides they are not remotely close to pristine condition. They are the original tags with the part # on them but no way to salvage them.I checked Rick's,Classic and D&R prior to posting  none of them list a YQ tag. Paul
Re: Spiral Shocks
« Reply #12 on: November 23, 2005, 05:12:18 AM »
What's the part # on the YQ tag?
Thanks!
Tinkerr
Re: Spiral Shocks
« Reply #13 on: November 25, 2005, 04:30:27 AM »
Hi Kurt,
the part # is 3909948
Re: Spiral Shocks
« Reply #14 on: November 25, 2005, 07:17:15 AM »
Thanks!
Here's a quickie list of 68 shock broadcast codes:
Fronts: TG - L6 & LF7,   PS - L35,   PW - L30/M20 & L35
Rears: TM - L6 & LF7,   TN - L35,   UM - LF7w/F41,   UN - L30/M20, L48, L35, L78, Z28
That list of the front codes is missing several models of cars. :(
« Last Edit: November 25, 2005, 05:30:11 PM by KurtS »
Mark
Re: Spiral Shocks
« Reply #15 on: November 25, 2005, 03:51:43 PM »
Don't often get to comment on Kurts postings (like never) but he really meant those codes are spring codes, not shock codes. ;D
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Re: Spiral Shocks
« Reply #16 on: November 25, 2005, 05:33:08 PM »
Geesum. I even double checked before I posted that!
Fixed it, it's now shock codes. Spring codes aren't as straightforward since they depend on weight.
Thanks Mark!
Pex68
Re: Spiral Shocks
« Reply #17 on: November 29, 2005, 02:00:18 AM »
Mark/Kurt,
REALLY appreciate all the info and help on this, I will now go with PW/TN for the shock codes, already have OH on the rear springs, but EG on the front.  I see the YQ referenced twice for L35 RS/SS cars so I'm hoping I'm good with the EG as my car is just an SS - Less weight? Any input??
Also, does anyone have a pic of a original date coded shock they can post to show the way it was stamped so I can replicate it when my shocks come in and where can I get the correct size/font punches from???
Thanks Again, Chris.
Chris P
Pex68
Re: Spiral Shocks
« Reply #18 on: February 22, 2009, 03:23:24 PM »
Chris
Wow, can't believe this was 3 years ago!  Anyway, Tinkerr, if you’re still looking this place lists an YQ spring tag:
http://www.ecsautomotive.com/
PN GFC13  1967 w/327; 350 CID Convertible w/AC (Code YQ)
Don't know anything about them, just stumbled across their site.
Chris P
redge
  • redge
Re: Spiral Shocks
« Reply #19 on: February 22, 2009, 07:21:05 PM »
Did someone knows the code for 1969 SS 350 m20 and F-41 suspension? thanks
Pex68
Re: Spiral Shocks
« Reply #20 on: February 22, 2009, 07:50:09 PM »
Are you asking about spring or shock code?  This post kinda got jumbled into both, think shocks were PS & UN for your app but I'm shootin' from hip on that.  As Kurt states above "Spring codes aren't as straightforward since they depend on weight"  If it's spring codes your after, search the site...Ed posted a sheet on how to figure that out somewhere.
Chris P
Mark
Re: Spiral Shocks
« Reply #21 on: February 23, 2009, 01:43:47 AM »
Spring codes are really tough to tie down, we started looking at them about a year ago and it quickly became clear that you can'tuse the GM service part books because GM consolidated multiple springs into common part numbers.  What starts out as a couple of dozen front and rear spring part numbers quickly get consolidated down into maybe 4 or five front and rear part numbers over the period of a couple of years.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
redge
  • redge
Re: Spiral Shocks
« Reply #22 on: February 25, 2009, 04:32:47 AM »
Thank you very much ,
jack
  • 69 camaro SS
Re: Spiral Shocks
« Reply #23 on: July 07, 2014, 07:05:11 PM »
Hi
For the 1969 SS L48 M20 with the code PS front and UN rear. What are the part numbers?  Am I right if I say  3192477 for the front and 3192851 for the rear?
