Author Topic: Fuel Vapor line SS350  (Read 12508 times)
abiddle
  • 1969 Camaro SS 350 - trim 719 52 52
« on: October 01, 2015, 02:48:59 PM »
I see a fuel and vapor hose kit for sale at Ricks, but I think I might be missing a metal line between the fuel filter and the vapor line. Pics of what I have are attached. I have an NOS fuel filter to install, but my vapor hose is cut. I would like to fix this, but I don't know what its supposed to look like and where can I get the best reproduction parts? (I would buy used or nos, but I assume both are going to be impossible to find.)
As always...Thanks!
Andy
abiddle
Re: Fuel Vapor line SS350
« Reply #1 on: October 01, 2015, 03:30:13 PM »
I found the metal vapor line in the trunk. I had an A-Ha moment after looking at fuel line pictures, I already had something that looks like this. So I just need the vapor hose kit. And if anyone has pics on the proper way the hose to vapor lines are supposed to appear at the connections please, that would be very helpful.
Thanks!
Andy
Boston14
« Reply #2 on: October 01, 2015, 10:11:10 PM »
Here's a picture of my 1969 L48 with the lines installed.
boston14
1969 SS/RS 350 Convertible
abiddle
« Reply #3 on: October 01, 2015, 10:28:58 PM »
Thanks, looks very nice.
crobjones2
« Reply #4 on: October 03, 2015, 02:29:20 AM »
mine:
Chris
69 SS 350
abiddle
« Reply #5 on: October 03, 2015, 02:06:37 PM »
Thanks - I ordered the vapor hose and I'll use these pictures.
« Reply #6 on: October 03, 2015, 02:57:00 PM »
Boston14, that motor looks great, how soon till it gets dropped in?
abiddle
« Reply #7 on: October 03, 2015, 03:05:44 PM »
Boston14 - are you putting the original style air cleaner on your L48, and have you found the correct crankcase breather hose? I'm still trying to figure out where to find this.
69pace
    • TeamCamaro - Moderator
« Reply #8 on: October 03, 2015, 09:46:40 PM »
I had the same style "plug" in mine only at the rear exiting the rail. The rubber had been disconnected from the fuel sender, the metal lead removed then sealed with bathroom caulk. The seal to the rubber hose was the insertion of a self-tapping screw and left as is.
When I replaced the tank and sender I wondered if there would be any fuel in the line. I put the rubber end into a container and shot air through the front and sure-enough the line was full of fuel. It wouldn't light so it was stale but since the front part of the system was intact fuel had been keeping the line full all those years. I let the line air dry a few hours before hooking the hose to the new sender and starting the car up.
So I would recommend that you disconnect your plug and the tank end and chase any fluid out that you find, why contaminate the fuel in the tank. Collect the contents and look for rust or other particles that may cause you issues down the road.
crobjones2
« Reply #9 on: October 04, 2015, 12:48:52 AM »
I second this question - does anyone know where to get a used/ repro breather hose/ and fitting?( valve cover to air cleaner)All I have found thus far are the 90* fittings that are incorrect for the L48  -  that and a stovepipe(exhaust to air cleaner)
Chris
69 SS 350
« Reply #10 on: October 04, 2015, 02:57:11 AM »
Chris, I posted on this: http://www.camaros.org/forum/index.php?topic=13686.0
The last post was that hose, I believe. Would like confirmation if that is what you seek?
crobjones2
« Reply #11 on: October 04, 2015, 01:25:19 PM »
I am looking for the straight tubing piece that comes out of the valve cover and into the 90* hose
Chris
69 SS 350
« Reply #12 on: October 05, 2015, 02:38:32 AM »
Did find a pic of my fuel return
abiddle
« Reply #13 on: October 05, 2015, 12:25:43 PM »
Thanks Kolektor - Are the worm gear or spring type hose clamps proper on both ends of the vapor and fuel lines?
« Reply #14 on: October 05, 2015, 12:57:01 PM »
spring clamp
« Reply #15 on: October 05, 2015, 12:59:07 PM »
Worm gear clamps correct? No. I am sure I have the correct spring clips. This is how it was when I got it and I have not really done anything with this car in eons. Anyone want a numbers SS 350 car?
Lower filter in pic is off a big block 69.
« Reply #16 on: October 05, 2015, 01:14:41 PM »
If you are giving it away then Ill take it.   :)
abiddle
« Reply #17 on: October 05, 2015, 01:18:18 PM »
Wow this forum is awesome, members give away numbers SS3350's! And here I thought my car was collectible.  :o
« Reply #18 on: October 05, 2015, 03:01:36 PM »
If you paint it and your other cars Hugger Orange, then yes, you can have it ::)
« Reply #19 on: October 05, 2015, 04:02:51 PM »
I have orange on both the big block cars..  Does that count?  ;D ;D ;D
« Reply #20 on: October 05, 2015, 04:07:36 PM »
Hard to argue that point. I knew you would figure a way to outsmart me.
« Reply #21 on: October 05, 2015, 04:09:36 PM »
So Ill be up in a few weeks to take ownership..   ;) ;D
Seriously though put it on craigslist and see what happens..
BSMIT59
« Reply #22 on: October 05, 2015, 11:55:12 PM »
Bentley are you about selling? PM me
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
BSMIT59
« Reply #23 on: October 05, 2015, 11:55:43 PM »
Add serious in there, I got too excited..........
crobjones2
« Reply #24 on: October 07, 2015, 12:28:03 AM »
before you sell it- assuming you are going to - I would love lots of pics- I need to see what I am missing
Chris
69 SS 350
abiddle
« Reply #25 on: November 15, 2015, 03:55:05 PM »
Well I've got something lined up wrong. To get the fuel line and vapor line to line-up I had to put the top of the vapor line behind the fuel-to-carb line. But it doesn't they don't line-up near the pump, and the AIM shows the vapor line in front of the fuel-to-carb line and clipped nicely near the pump. Sadly I don't know if this was an original vapor line, it was in my pile of long-ago purchased parts. Or maybe I just have it messed up.
Suggestions on where I can get the correct clips?
Thanks - Andy
crobjones2
« Reply #26 on: November 15, 2015, 04:14:00 PM »
spin the filter forcing the vapor line to the front.
I believe I purchased my re-pro's from steve's or rick's
I have seen them at classic industries
Chris
69 SS 350
