Author Topic: Brake Booster Valve Tag  (Read 7915 times)
DDZ28
« on: August 03, 2015, 04:02:40 PM »
Need a little help.
I have a 9978 original mile L78 car with a brake booster valve tag CG and I cannot find a replacement. I can only find CH & CU.
Any help locating would be great.
69 Z/28 Camaro LeMans Blue (Current Ground Up Restro)
68 SS Camaro L78 LeMans Blue (9977 Original Miles)(Next Ground Up Restro)
68 Z/28 RS Camaro Corvette Bronze (some where down the restro line)
68 Standard Camaro LeMans Blue (maybe a Resto Mod someday)
Re: Brake Booster Valve Tag
« Reply #1 on: August 03, 2015, 05:34:07 PM »
The paper on the repros is too thin.
I would take the original have a ink stamp made with CG and stamp my own.
They were on manilla or buff stock, you have the original I believe the thickness is approx .030-.035.
Uncoated Milkcarton stock would work well as it has wet strength added.
« Reply #2 on: August 03, 2015, 07:42:50 PM »
Speaking of brake booster check valve tags..  I ran across this the other day and can not find what it was used on.  Anyone have any idea.
Camarocards
« Reply #3 on: August 04, 2015, 06:06:10 PM »
Dan,
Quote
X2. When it came time to replicate the stamp on my wiper motor (see pic below) I created the artwork and had a stamp made by the Stamp Connection (http://www.stamp-connection.com/). Very good people to work with and it cost $10.95 for the stamp. If you need help creating the artwork send me a PM.
James,
Quote
I dug up the tag that I purchased years and years ago and it measures .030 but the stock is much more yellow in color than what Dan has posted or what I see being offered by the repro companies. Do you know if the tag is suppose to be white or more yellowish in color?
Bob
Bob
'68 SS L35 01D
DDZ28
« Reply #4 on: February 10, 2017, 04:31:00 AM »
I have had the CG tag made by a print shop. I think it looks pretty good.
« Reply #5 on: February 10, 2017, 06:44:58 AM »
I assume the 2-letter code denotes the valve and hose as an assembly, but were the differences in the check valve, the vacuum hose, or both?
« Reply #6 on: February 10, 2017, 01:05:33 PM »
Was your L78 a power disc or power drum car?
DDZ28
« Reply #7 on: February 10, 2017, 01:18:31 PM »
Tim, I don't know the answer to your question, maybe someone else will pipe in and let us know.
Darrell, this car is a power drum car.
« Reply #8 on: February 10, 2017, 03:04:32 PM »
Thanks.  Just curious what are the plans for the original one?
BillOhio
    • photobucket
« Reply #9 on: February 10, 2017, 03:32:07 PM »
I think this requires pictures of the car and why so low of miles??
1968 RS 327 4 speed
DDZ28
« Reply #10 on: February 10, 2017, 03:45:39 PM »
It came apart during dis-assembly.
Attached is a photo of the original, the one I had made and the after market one (right)
DDZ28
« Reply #11 on: February 10, 2017, 04:08:49 PM »
Bill, This car sat in a concrete block garage in the woods of WV for 42 years, needless to say it had a bit of rust issues and had to go through a complete restoration.
« Reply #12 on: February 10, 2017, 04:58:39 PM »
Personally, as a 'preservationist', I really like the original one...  better than any repro~   :)
Z28Project
« Reply #13 on: February 10, 2017, 07:05:25 PM »
The one you had made is obviously way better than the aftermarket one.
Preserve the original, use your repop, and throw the 3rd one away! :)
John
BillOhio
    • photobucket
« Reply #14 on: February 11, 2017, 12:44:22 AM »
Probably a good original car to do. Good luck!
1968 RS 327 4 speed
