Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
AAW 69 Engine harness differences
« previous
next »
Print
Pages:
1
2
All
Author
Topic: AAW 69 Engine harness differences (Read 11477 times)
Hero Member
caretaker of 1971 LT1's 11130 & 21783
Re: AAW 69 Engine harness differences
Reply #15 on:
August 04, 2015, 03:23:56 PM »
The bracket which bolts to the bell housing is coated on the original and is bare on the repro, are they using black harness clips again or are they still white?
Logged
BillOhio
Hero Member
Reply #16 on:
August 05, 2015, 12:34:54 PM »
Is the coating a paint? One they sent was cad plated. I just got the harness to my starter, header had worked on it a bit.
Logged
1968 RS 327 4 speed
Hero Member
Reply #17 on:
August 05, 2015, 12:52:53 PM »
Its coated to keep from cutting the wires.. MY original harness on the 67 & both 8's are the same as what James posted above.
Logged
BillOhio
Hero Member
Reply #18 on:
August 05, 2015, 02:27:20 PM »
Ok yeah the new one wasn't. I thought I might swap mine
Logged
1968 RS 327 4 speed
Hero Member
Reply #19 on:
August 05, 2015, 02:54:03 PM »
No not paint like plasti dip.
Logged
Hero Member
Reply #20 on:
August 21, 2015, 01:46:41 PM »
The wiper motor wiring as mine came exactly like the original. I used my original to make up a test set up. I need to check that bell housing bracket (pretty sure I used the original)! Thanks James!
Logged
R 68Z build-
http://www.camaros.net/forums/showthread.php?t=182584
BillOhio
Hero Member
Reply #21 on:
August 21, 2015, 01:57:23 PM »
Wonder why the 69 is different when chick's has the same colored wire and connector as mine? Shaking my head!
Logged
1968 RS 327 4 speed
69pace
Hero Member
Reply #22 on:
August 21, 2015, 03:27:01 PM »
The plastic can be changed out easily if the brown bothers you or you can remove it, paint it and then reinsert the leads.
I'll have to look at my jumper wire, thought it was blue.
Logged
TeamCamaro - Moderator
BillOhio
Hero Member
Reply #23 on:
August 21, 2015, 06:11:45 PM »
Guy I talked to acted like mine was made wrong. I was like well it needs fixed!
Logged
1968 RS 327 4 speed
Print
Pages:
1
2
All
« previous
next »
Restoration
