Author Topic: 1969 302  (Read 14604 times)
Boarsnest
« on: June 10, 2015, 02:09:38 AM »
Hi I'm new here.  I've got a 69 302 short block
Casting #3932386
Pad#    V1027DZ
Date.    J88
Crank.    1178
I can't find the partial vin on it.
« Last Edit: June 10, 2015, 02:10:37 AM by Admin »
Re: 1969 302
« Reply #1 on: June 10, 2015, 06:07:34 AM »
Welcome to the CRG!
Are you trying to find the partial VIN in order to put the motor with the original body?
The partial Vin is very hard to see even with the block in good lighting and out of the car. It will be in the rough casting above the oil filter location. It is going to start with 19N******.
How did you come across the block?
Boarsnest
Re: 1969 302
« Reply #2 on: June 10, 2015, 12:42:41 PM »
I was trying to find the vin because I think the engine would be better off in a car that needs it,as opposed to being drag raced to death if I keep it 😉 I actually bought the engine as a 327 for my 54 Chevy,and under closer inspection it turned out to be a dz
262jp
Re: 1969 302
« Reply #3 on: June 10, 2015, 01:02:39 PM »
Since this is an October 1968 casting the vin should be on the pad. It wasn't moved to the location by the oil filter until later.
click
    • Our 69 RS
Re: 1969 302
« Reply #4 on: June 10, 2015, 02:00:52 PM »
My LOS Oct 68 LM1 has partial VIN by the oil filter, so it is safe to say, look at both areas. VIN's were being moved around alot back then depending on if it was built in NOR or LOS (Van Nuys) .
Click is Jim , central Minn.  Moderator at Team Camaro www.camaros.net
Boarsnest
Re: 1969 302
« Reply #5 on: June 10, 2015, 05:26:17 PM »
Well it's definitely not on the pad. I guess I'll have really look by the filter
Re: 1969 302
« Reply #6 on: June 10, 2015, 05:35:42 PM »
It may take a few different people looking at it with good lighting, but when you see it all of sudden it will pop out at you.
x66 714
Re: 1969 302
« Reply #7 on: June 10, 2015, 11:50:13 PM »
I was able to read mine using a camera with a flash from different angles. It shows up in the shadows...Joe
Re: 1969 302
« Reply #8 on: June 16, 2015, 01:18:15 AM »
Try to post a pic of the engine pad if you can.
And as for the oil filter area, try rubbing some chalk on that area and then look again.  It's easy to clean off if you can't see anything, but sometimes that helps.
Good luck.
Boarsnest
Re: 1969 302
« Reply #9 on: June 16, 2015, 03:11:03 AM »
Here's the pad
Re: 1969 302
« Reply #10 on: June 16, 2015, 03:19:29 AM »
Your deck has been milled, broach marks are no longer visible, and the stamped characters are not in alignment... which is out of the norm for factory stamps that I've seen (at least a few hundred)...
FortLangleyBC
Re: 1969 302
« Reply #11 on: June 16, 2015, 04:12:45 AM »
My JM certified DZ stamp is pretty much perfectly aligned as suggested by 69Z28-RS & broach marks are visible.
I'm no expert but this looks like a re-stamp to me as well.
1969 Trans Am 400 335 WQ Cameo White
dannystarr
Re: 1969 302
« Reply #12 on: June 16, 2015, 06:05:19 AM »
I too am no expert, but I would bet big money this has been decked and restamped. NEVER seen a sloppy crooked stamp from the factory like that. I wouldn't bother looking for the VIN. Unless ya wanna just see for fun.  ;D    D
Stingr69
Re: 1969 302
« Reply #13 on: June 16, 2015, 12:30:13 PM »
obvious bad restamp.
Boarsnest
Re: 1969 302
« Reply #14 on: June 16, 2015, 12:58:18 PM »
A couple questions, would it have been restamped because of having the deck milled? And even with the correct crank, caps,and block casting #, it's of no use to a restorer? Just curious before i load it up with nitrous and beat it at the track
