Author Topic: The straight skinny on post '65, pre-mid '70, Hurst shifter plating  (Read 13805 times)
vtfb68
Re: The straight skinny on post '65, pre-mid '70, Hurst shifter plating
« Reply #15 on: January 28, 2015, 10:14:21 PM »
I have a 68 Camaro NOS Comp + aftermarket shifter (in the original box) tucked away for future use, Is there any info or numbers that would help with this topic? BTW is the mounting the same for a Small and big blocks? The off-set should not come into play as hursts are transmission mounted.
    VT
68 08E LA RS Y2 749 L30 M35
Shadow Ahead
« Reply #16 on: January 29, 2015, 05:57:19 PM »
Appreciate the input gents. If there are materials available with notes to cross-reference that is what I'm seeking. Otherwise, with no bad intent directed at anyone, opinion or regurgitated "facts" with no back-up. Already covered this ground elsewhere.
I'm looking to break new ground(or uncover old earth), actual proof. If it exists, and is available, it benefits all. Even a nod in the right direction would be of benefit.
Shadow Ahead
« Reply #17 on: January 29, 2015, 11:25:17 PM »
" Otherwise, with no bad intent directed at anyone, opinion or regurgitated "facts" with no back-up"
Meant to say documents are what is needed.
« Reply #18 on: January 29, 2015, 11:45:44 PM »
Good luck Steve, but I doubt you will find any documents with what you are looking for.
Shadow Ahead
« Reply #19 on: January 30, 2015, 01:12:47 AM »
^Yeah,unless the I contact I'm thinking of can confirm. If I get them, their word will suffice. But that is only one person in the world…
JoeC
« Reply #20 on: January 31, 2015, 05:38:35 PM »
Joe,
What changed on the 67-8  aftermarket shifter?
The original 67-68 Camaro Hurst aftermarket shifter has a two piece welded neck
Then in about 1969 they changed to a stamp steel neck and used it for 67-69 Camaros and still use today
now you get same shifter for 67-69 but 69 uses a different stick
The original Camaro Hurst used a curved stick and shifter is silver cad
I have an original with the stick and have the original install sheet that shows it
It was also shown in the 1967 Camaro Hot Rod Magazine article where they claimed it was the first Camaro to get a Hurst shifter
That article inspired my search to find one ,was hard to find as not many around anymore
Shadow Ahead
« Reply #21 on: February 02, 2015, 10:06:42 PM »
Does the install sheet show any materials/processes used or only how to install?
JoeC
« Reply #22 on: February 05, 2015, 10:32:52 PM »
instruction sheet shows contents, part numbers, assembly drawing and info
does not say what finish was used
Shadow Ahead
« Reply #23 on: February 13, 2015, 04:17:01 AM »
^ Thanks.
