Author Topic: 1970 Brake Distribution/Pressure Differential Switch  (Read 3656 times)
sah62
    • Muscle Car Research LLC
« on: January 02, 2015, 06:28:06 PM »
I could use some help identifying a pair of original brake pressure differential switches. I've attached a pair of pictures that I hope will better explain my question.
Which of these (if either) is a 3983040 brake pressure differential switch as used on a 1970 Camaro? The only difference I can see is that the cleaner one includes a plugged fluid port in a place where the dirty one is solid. The internal parts are identical. I have two like the dirty one that I bought as advertised for a 1970 Monte Carlo (which the parts catalog seems to group with Chevelles) and a 1970 Camaro. So, what are these? What other cars were they used on?
Thanks for any insights...
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang R-Code Mach 1
2006 Dodge Charger SRT8
1995 Chevrolet Impala SS
L78 steve
Re: 1970 Brake Distribution/Pressure Differential Switch
« Reply #1 on: January 03, 2015, 06:15:36 PM »
My 70 Nova has this set-up. I will snap a pic. when I get home Tues.
69 Z/28 Dover White. SOLD
L78 steve
« Reply #2 on: January 25, 2015, 08:49:41 PM »
Pics. 70 Nova. This set-up is 70 only Nova and Camaro. It has the distribution block, frame valve and golf ball valve all together. My dist. block does not have the extra port that one of yours has.
