Author Topic: Motor vin stamp vs. transmission vin stamp  (Read 23947 times)
« on: December 30, 2014, 09:18:13 PM »
Well I am not sure if this has been discussed before or not. When ( at what time during assembly, not actual date) was the motor stamped with the vin number by the oil filter, and was the transmission also stamped during this time with the vin number? Were the two mated together already and stamped with the same gang stamp? Just curious how and when this happened to both.
thanks
Re: Motor vin stamp vs. transmission vin stamp
« Reply #1 on: December 30, 2014, 09:41:14 PM »
From JohnZ's Camaro Assembly Process Report...
"In the engine schedule area, the operator grabbed the next Broadcast Copy from the printer, verified the sequence number, noted the engine code required for that car, and moved an air-powered overhead hoist on traveling bridge rails over the correct engine rack. The specified engine was hoisted out of the rack and transferred to the next hook on the overhead engine dress line conveyor, where the throwout bearing (on manuals) was greased and installed, along with the clutch fork boot. Another operator on the other side of the line repeated the process with the specified transmission, which was then installed and bolted to the engine; on automatics, an air tool was used to rotate the flexplate, and the converter bolts were driven, followed by the lower cover. The VIN derivative numbers were stamped in the next operation on both the engine pad and the transmission, using a gang-stamp holder and a hammer. From here on, all the detail dress items were added (plug wires, coil, engine harness, battery cables, carburetor, pulleys, alternator, starter, fan and clutch, A/C compressor, power steering pump, transmission cooler lines and fill tube, A.I.R. pump, diverter valve and air manifolds, drive belts, dipstick and tube, oil filter, engine and transmission mounts, PCV plumbing, vacuum fittings, fuel pump and fuel line, radiator hoses, and (if applicable) the transmission-mounted 4-speed manual shifter and linkage was installed and adjusted (3-speed manual floor shifters were mounted on the cross-member and adjusted later on the Chassis line). Engine oil and transmission lube were added, and the completed engine/transmission assembly was conveyed to the Chassis Line for installation in the subframe. The engine line inspector wrote the engine, transmission, and carburetor codes on the Broadcast Copy and put the sheet in a box for pickup by a Scheduling clerk (needed to create the P-O-P at the end of the Final Line)."
« Reply #2 on: December 30, 2014, 10:35:42 PM »
Ok 2 questions. First in Johns report, shouldn't it say Pilot bearing, instead of throwout bearing? (I thought the pilot bearing was the one fitted to the back of the block) throw out bearing I thought was mounted to the clutch fork right?
Second in your post I didn't see if they were stamped using the same stamp, or 2 different gang stamps. Looking closely at my trans and motor it appears to be a different stamp, but maybe it just looks different because it is deeper into the softer aluminum on my trans?
« Reply #3 on: December 30, 2014, 10:54:56 PM »
there's nothing wrong with how JohnZ stated it...  both the pilot bushing and throwout bearing would have to be installed prior to mounting the trans to the engine.  I've also heard it said many times in this forum that the two stampings were done with the same gang stamp (why take the time to change two different gang holders when one can do that job in a few seconds?)..  and Yes, your transmission stamping should be very clear, whereas the engine stamping (VIN) on the cast surface is not very deep, and will look differently on that rough hard surface than does the same stamping on softer smooth aluminum.
jack92584
« Reply #4 on: December 31, 2014, 12:49:25 AM »
My understanding is that the trans and block vin stamps should be identical as they were done at the same time. Having said that I also remember reading that there are confirmed cases very late in the 69 model year where for unknown reasons different stamps appear to have been used.
69 Z28 / Hugger Orange /  Deluxe Houndstooth  / M21 / 4:10 Posi / GM of Canada documented
« Reply #5 on: December 31, 2014, 01:50:21 AM »
I've seen a few examples in 69 where they didn't match.
« Reply #6 on: December 31, 2014, 02:26:09 AM »
I guess I try to understand why there is a mismatch in some stampings when that is noted. John certainly could verify this, but a plausible reason, IMO, is that in a hurried environment and some carelessness factored in, some trans or other units may have gotten damaged before they made it into the chassis and had to be replaced, hence a different stamping. Just throwing that out there while it was on my mind.
« Reply #7 on: December 31, 2014, 03:26:38 AM »
Bentley, I think Kurt is referring to the stamping font on the  gang stamp not matching, not that the vin numbers are different.
« Reply #8 on: December 31, 2014, 01:28:43 PM »
That (font and any other irregularity in partial VIN stamp comparisons of matched block vs trans) is also what I refer, apologies for any ambiguity. If another unit (I.E. trans. or other major component) was exchanged during the assembly process because of damage on the line, the new unit would have had to have the partial VIN added on the line. That replacement's stamping may not be identical in appearance to the engine block's stamping .
Disclaimer: I am no JohnZ and was not involved in any automotive factory. This is just a supposition and opinion of what may have occured to explain irregularities in appearance of partial matching component VIN stampings. Shoot, I have not been through the Norwood plant since I toured it as a Cub Scout in 1970! I was 9 years old! Y' all have a Happy, safe, productive, New Year...like a fine wine, all our cars will literally become a year older tomorrow.
« Reply #9 on: December 31, 2014, 02:25:43 PM »
46!!   Prime of their lives...  :)
68 Ragtop
« Reply #10 on: December 31, 2014, 06:09:50 PM »
Since the motors are already coded for transmission type, wouldn't the pilot bearing already be installed?
Perhaps that's why JohnZ didn't mention it.
« Reply #11 on: December 31, 2014, 06:51:35 PM »
Good point.
« Reply #12 on: December 31, 2014, 10:47:13 PM »
Pilot bearing would have normally been installed before the engine and transmission were mated together.
If the partial VIN stamp on the engine and transmission do not match, that should raise a yellow flag.  It is possible they are both factory stamps, but it does raise questions and I would have Kurt take a look at both to verify.  But that is your call.
« Reply #13 on: January 02, 2015, 08:14:01 PM »
The pilot bearing was installed at the engine plant, before they installed the flywheel, clutch, and bellhousing.
There are several potential explanations for differing formats between the two VIN derivatives, most likely related to individual operator work assignments and how they changed during the year as manpower adjustments were made or as Engineering specs for each stamp were revised. Unfortunately, we don't have those records. I've always been baffled by the VIN moving in 1969 from the pad to the oil filter - the plant controlled when the alternator was installed, so they must have had another reason why they took it off the pad to the oil filter area - we don't have those records either.
« Reply #14 on: January 02, 2015, 09:51:10 PM »
You're not the only one to ponder the WHY of that move JohnZ...  :)    One potential reason for that, as I ponder the possibilities, is as follows:
Supposedly the reason for the VIN stamping on the engine is for 'legal purposes'.. ie. association of the engine with a specific vehicle, theft deterrent, etc.  By 1969, many machine shops and owners were decking their blocks for increased compression, which in addition to 'removing the 'engine application stamping', would also remove the VIN (if it stamped on the deck surface.  As muscle car owners, street racers, etc..  Why should we care if those 'meaningless' stampings were removed~??    :)
There is essentially zero chance that the VIN would be machined away (accidentally) if it placed down there on the cast surface.   In fact, I think it was several years before people realized that Chevrolet had moved the VIN stamping to the block rough cast surface.  I believe it was around 1979 before one of the car magazines published as part of a 'Camaro Decoded' sets of articles, that the VIN stamping on the engine was moved down to the side of the block.
The 'con side' of that logic is, as we all know, it's very difficult to legibly discern the VIN on that rough cast surface even when the engine is removed and cleaned/examined, etc, and practically impossible to read the VIN with the engine in the car!
« Reply #15 on: January 03, 2015, 03:59:13 PM »
Probably will never know the reason why the partial VIN derivative stamp on engines moved around in 1969.
Just like we will probably not know the reason why the partial VIN stamp on transmissions on some Chevelles (mainly Kansas City plant in 1968 ) moved around too.
8ballracing
  • 2004
« Reply #16 on: January 04, 2015, 10:08:07 PM »
"There is essentially zero chance that the VIN would be machined away (accidentally) if it placed down there on the cast surface." (Posted by: 69Z28-RS)
X2  Removal of the vin from the cast surface would be hard to explain to the authorities in the case of a stolen car or to GM for a false warranty claim, just a thought.
« Reply #17 on: January 05, 2015, 09:37:01 PM »
Unlikely that was the reason (at best).  OTHERWISE it would be there for ALL cars....
jdv69z
  • 69 RS Z/28 52E
« Reply #18 on: January 06, 2015, 02:10:41 PM »
My guess would be that the change had to do with improving the assembly process, however the move accomplished that.
Jimmy V.
x77-69z28
« Reply #19 on: January 07, 2015, 03:09:37 AM »
I had read some where that it was due to the alternator being relocated to the passenger side for 69. The alternator had to be removed to stamp the vin.
Buddy
« Reply #20 on: January 07, 2015, 03:28:36 AM »
Buddy
The partial VIN was stamped on the engine pad before the alternator was installed.  Read below...
« Reply #21 on: January 07, 2015, 05:43:33 PM »
Buddy
That's one of the great misunderstandings that surrounds the VIN derivative location issue; the engine arrived "bare naked" from the engine plant, and the alternator was installed (with all of its mounting bracketry) on the plant's Engine Dress Line, and the process sequence was at the plant's discretion. For some reason (which we'll probably never know), they elected to change the process and relocate the VIN stamping work element to AFTER the alternator installation. That relocation of the VIN from the block pad to the oil filter area required Engineering approval, but I've never seen anything that documents it.
Kelley W King
« Reply #22 on: January 08, 2015, 08:32:23 PM »
When you bare naked, it did have engine code?
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #23 on: January 08, 2015, 08:35:42 PM »
The application code was stamped where the engine was assembled (Flint or Tonawanda)...
« Reply #24 on: January 09, 2015, 04:32:09 PM »
<< When you bare naked, it did have engine code? >>
Photo below was shot at Tarrytown in 1959, but engine state of dress from the engine plant didn't change any from then to 1969; the block pad had the engine plant machine stamp, but the only bolt-on part on the engine was the distributor.
« Reply #25 on: January 10, 2015, 03:06:18 AM »
That's a whole bunch of 283 double barrel injuns. I love the painted ram's horns exhaust manifolds - never seen that one before. Slick -
« Reply #26 on: January 10, 2015, 04:55:15 AM »
That paint was probably burned off by the time the new cars made it out of the plant to the holding lot...  :)
« Reply #27 on: January 11, 2015, 06:03:50 PM »
I added that pic to John's article years ago.
http://www.camaros.org/assemblyprocess.shtml#chev
jdv69z
  • 69 RS Z/28 52E
« Reply #28 on: January 11, 2015, 06:46:33 PM »
So I was looking at the report and saw that Firebird was added to Norwood in 69. How was this accomplished? Would the Camaro fixtures work on the Firebird as well, or was there different fixtures/equipment depending on the build?
Jimmy V.
« Reply #29 on: January 15, 2015, 07:54:57 PM »
Most of the basic (Fisher Body) body tooling was the same except for only minor part differences; on the Chevrolet side of the plant, new tools/fixtures were built for the Pontiac-specific assemblies, holes had to be drilled in the subframe for the clip screws for the Pontiac left-side fuel line, etc. Lots of new parts and tools, lots of operator training. Two car lines with the same 2-door body was a piece of cake - many GMAD plants ran THREE car lines (like Buick, Olds, Pontiac) plus Chevy, with the full range of body styles from 2-doors to 4-doors to convertibles to 9-passenger station wagons, all on the same line.  :-)
pjbizjak
« Reply #30 on: January 15, 2015, 08:55:28 PM »
John Z, Shouldn't the VIN on the engine pad match the VIN on the cowl tag?
jdv69z
  • 69 RS Z/28 52E
« Reply #31 on: January 15, 2015, 09:00:35 PM »
So a 2 door could be followed by a station wagon? I can see once the basic body is welded up on the Fisher end where the rest of the process is mainly a matter of the correct parts coming from the various feeder lines. It's the beginning part where the various sheet metal parts were being lined up and welded that I find amazing, especially when two basically different bodies were one right behind the other. I guess the tooling mainly involved holding the parts to be welded, and there were locating holes/pins in the parts themselves? Or maybe the fixtures were universal, and had locating pins to work with every body to be built?
Jimmy V.
« Reply #32 on: January 15, 2015, 11:15:10 PM »
Pete, this is no VIN on the cowl tag.
« Reply #33 on: January 16, 2015, 04:21:55 AM »
I still think the wildest line I've seen was in the Ford Wixom plant. The same line built Town Cars (rwd frame), Continentals (fwd unibody), and then added the Lincoln LS (rwd unibody). They were all mixed coming down the line.
Nowadays, all the cars have common reference points and it's not so much of an issue, but that's just come about in the last decade+. They had to, to allow for more plant flexibility for volume slowdowns, popular models, etc.
« Reply #34 on: January 16, 2015, 07:10:18 PM »
There is no VIN on the cowl tag - only the body number; the VIN tag (visible through the windshield) is riveted to the upper instrument panel, and is unrelated to the body number.
« Reply #35 on: January 16, 2015, 07:21:18 PM »
Most plants had a common underbody build truck in the Body Shop (except Lordstown, which had one for full-frame "B"-bodies and a different one for half-frame "F"-body Firebirds), and each different body style (2-door "F"-body coupe, convertible, 2-door "B"-body coupe, 2-door "B"-body 2-door hardtop, 4-door sedan, 4-door hardtop, and 4-door station wagon) had multiple left and right pairs of side frame gates to build up the body side and then assemble it to the underbody (which included the cowl). Assembly at 65 per hour was a VERY complex business, not for the faint of heart.
