Correct Dip stick
L78 steve:
What is the correct dip stick for a late 67 L78, Yellow or red tip?
Mike S:
Would it be the same as an L35? If so then mine are both pink. The sumps should be the same size.
Engine dates are T0214 and T0308
I assume the sticks were installed when the motor was assembled?
L78 steve:
Are they pink or faded red?
Mike S:
That's a good question...pink or faded red. I had to check again.
I was able to remove the button from one dipstick easy enough and comparing the
exposed to the non-exposed area they look the same pink color.
L78 steve:
Pink it is. Thank you for your efforts.
Navigation
[0] Message Index
[#] Next page
