Chambered exhaust change out
(1/1)
sbmiano:
If I wanted to change out my chambered exhaust with the stock exhaust is it an easy swap? hangers and route of pipes same as the chambered? Where would I get5 a stock exhaust which I think is 2 3/4 inch?
Thanks for the help
Scott69Z:
If your chambered exhaust is a Gardner I would be interested in buying it if you wanted to sell it.
69Z28-RS:
This is probably the best deal on a stock exhaust system for the '69 Camaro....
http://www.drclassic.com/catalog/Camaro/Exhaust/Z00088.html
sbmiano:
Thanks... does the exhaust fit the exact same way as the chambered exhaust? Just want to un bolt and bolt on.
69Z28-RS:
Scott,
Some of the hangars are different.... but they should all mount to the floor or framemember in the same locations and use the same holes. Should not be an issue if it's all stock.
Gary
Navigation
[0] Message Index
