Author Topic: Galvanized finish on 67-68 tail light housings, hot dipped or electroplated?  (Read 13018 times)
Leon in Mn.
Well my 67 LOS built 03C car is different again.  The rear tail light assemblies have Phillips screw fasteners on the drivers side and pan head screw fasteners on the passenger side.  Does this mean that there were two different assemblers on each side using two different bins?  I never noticed this before, and they are the originals.
Mine does have the same pan head screws as yours Mike.
When you say 'pan head' are you referring to hex? I ask this only because you made a distinction between Phillip and pan head in reply #15
Leon in Mn.
I'm sorry....I meant to say "hex head" screws with the large G and the L inside the G,  imprinted on the head itself.
Year  Tag date   Plant  Head type
67      11B          LOS   Hex
67      11E          NOR   Phillip (L&R)
67      03C          LOS   Phillip (R) & Hex (L)
67      04B          LOS   Hex (L) & Phillip (R)
67      05B          NOR   Phillip (L&R)
67      05E          NOR   Hex   (L&R)
67       ?                ?    Phillip (L&R) - posted by 69z28-rs
68      03D          NOR   Hex   (L&R)
[/quote]
MyRed67
  • SZZLN 67
  Did the tail-lights come into the factory as an assembly?  Is it possible there were more than one supplier?
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
LVN 67
  • John 67 NOR 02E L-35/T400, 6th Owner
My 67 02E NOR car has Phillips (L&R)
68 01B Hex both Left and right!
