Author Topic: 1968 SS 350 intake manifold  (Read 8740 times)
gro51
  • 68 SS/RS 350
« on: September 17, 2014, 01:47:30 AM »
Can someone please tell me the correct part number for the intake manifold for a 1968 Camaro SS 350?  Thank you.
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
Re: 1968 SS 350 intake manifold
« Reply #1 on: September 17, 2014, 02:26:24 AM »
The casting number is 3919803.
gro51
  • 68 SS/RS 350
« Reply #2 on: September 17, 2014, 11:18:43 PM »
Thanks Paul.
Joe
Schodack, NY
gro51
  • 68 SS/RS 350
« Reply #3 on: September 24, 2014, 02:17:06 AM »
I have an intake from a 1966 327.  Part number 3905393.  I am not that interested in a correctly numbered intake at this point.  The one I have looks identical to the 3919803.  Would it work/perform okay?
Joe
Schodack, NY
« Reply #4 on: September 24, 2014, 02:51:17 AM »
As long as it is the same configuration, meaning same carb holes size, it should work fine and is essentially the same as the noted correct intake. It may be a 1966 date, but it's application is for a 67 327 and 350 for Q-jet. If it is, in fact, a 66 intake, it would be for a Carter AFB, so make sure the secondary holes are larger as a Q-jet would be.
The casting says it is 67 Q-jet and the Q-jet was introduced in 1967.
gro51
  • 68 SS/RS 350
« Reply #5 on: September 24, 2014, 09:55:32 PM »
Excellent ko-lek-tor!  Thanks for your help.  :)
Joe
Schodack, NY
BSMIT59
« Reply #6 on: March 17, 2015, 03:01:55 PM »
Soooo......  The correct intake # for a 1967 SS 350 engine would be 3905393 with a J266 date ?
Thanks in advance!!
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
« Reply #7 on: March 17, 2015, 03:25:49 PM »
Thanks in advance!!
If it's a Tonawanda engine, yes - that's a Tonawanda-cast intake.
BSMIT59
« Reply #8 on: March 17, 2015, 04:35:20 PM »
Interesting. Thanks John. I do have an original 327/275 Tonawanda in the 67 SC that hasn't been touched but I'm trying to find an original for my 67 SS350 to have it period correct. The block that I have for it now is not original to the car but it is a 67 350.  It's a V0906MS  stamped block.
BSMIT59
« Reply #9 on: March 17, 2015, 11:46:55 PM »
My original 67 sport coupe with a build date of week 4 June 1967(end of run) has all of the original parts and the intake shows as a 1968 #3919803 dual plane quadrajet intake for the engine code T0616MM. Is this possible?
« Reply #10 on: March 18, 2015, 12:38:37 AM »
I believe that intake may have been used late in the 1967 model year.  What is the casting date? Compare that to the assembly date of the engine.
