Author Topic: Wanted 1969 Camaro Rosewood Dash portion with rear defroster hole  (Read 2961 times)
zipppo
« on: September 04, 2014, 12:20:27 PM »
I am adding a rear defroster to my 1969 Camaro.
I need the Rosewood dash piece (metal) that attached to the carrier that typically has the headlight switch and wiper switch holes. I am looking for the one with the extra hole for the rear defroster.
Thanks in advance.
Re: Wanted 1969 Camaro Rosewood Dash portion with rear defroster hole
« Reply #1 on: September 04, 2014, 01:29:04 PM »
Try posting on Team Camaro, they have a wanted/classified section.
« Reply #2 on: September 04, 2014, 02:14:43 PM »
Wouldnt one from a convertible work or is that a different location?
« Reply #3 on: September 05, 2014, 05:11:44 AM »
Not a common or cheap part. Last one I saw on ebay went for $100.
sdkar
« Reply #4 on: September 05, 2014, 07:48:05 AM »
I think I have one...email me and I will send a pic to see if it will work.  It's actually a regular one, but someone installed a switch in the defroster area, and if you enlargen the  hole properly for a defroster, it should work.
dekar@bellsouth.net
