Go to full version
68 Transmission Tunnel cut out identification
<< < (2/2)
janobyte:
As usual ,I agree with you Cook. Never had to cut mine and over the years I had a Hurst Comp shifter and a B & M Ratchet when it had the auto . No bells and whistles were on it however. Something like a Cheetah (superior :) has a lot of beef under it.
L78 steve:
My 69 shifter hole looked like that, It had a Super Shifter installed.
bcmiller:
I would agree with the possibility of a Super Shifter being in there at one time.
Can you take a picture from the underside?
Go to this link and scroll down to the Transmissions section.
http://www.camaros.org/options.shtml
An original 67 floor shift tunnel and an original 68 manual transmission floor shift tunnel will both look like this.
Someone does make that reinforcement plate as a reproduction part now.
(Edit was to correct wording)
L78racer:
Were the hole locations for the console mounting and riv-nuts drilled through based on dimples in the tunnel panel or were they somehow done using a template or other? thank you.
68Zproject:
Dimples as I recall.
Navigation
[0] Message Index
[*] Previous page
