Author Topic: Sticky speedo  (Read 4399 times)
Mark's 68 L78 RS SS
Sticky speedo
« on: October 12, 2006, 07:11:23 AM »
Hi guys:
My speedo is sticking and not reading the right speed.  Any special tricks to replacing the cable?  I see there are several lengths available so I will need to research which one is correct for a 68 L78 with M22.
Thanks in advance for any advice.
Mark
Mark
Skaneateles, NY
68 L78 RS SS M22
lakeholme
  • 68-12D L30/M35
Re: Sticky speedo
« Reply #1 on: October 12, 2006, 01:50:56 PM »
Are you sure you just don't need to lubricate the speedo cable.  A year or so ago, the speedometer on my 68 buzzed and jumped around.  A little lubrication and it's worked fine since.  Your local parts store should have the lubricant (It's got graphite in it... although some folks swear by white grease and a low viscosity oil combination.)  The point is you will have the cable out as it is, so if it looks dry, try the cheap fix first.
Mark's 68 L78 RS SS
Re: Sticky speedo
« Reply #2 on: October 12, 2006, 08:46:44 PM »
Philliip:
You make a good point and we already lubed it once.  i will check to make sure we did it good but I am thinking I will just replace it.  They are not too expensive and it will just eliminate the problem.
Mark
Mark
Skaneateles, NY
68 L78 RS SS M22
