Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
My New '68 Camaro Z/28 Butternut Yellow
« previous
next »
Print
Pages:
1
42
43
44
45
46
57
Author
Topic: My New '68 Camaro Z/28 Butternut Yellow (Read 371614 times)
dannystarr
Hero Member
Re: My New '68 Camaro Z/28 Butternut Yellow
Reply #645 on:
December 23, 2014, 09:44:45 AM »
Picked up some more parts. Got an original late '68 build solid rivet Rad Cap, Repro Battery Cables, Spark Arrestor, Wiper Arms, Blade Holders, ... Repro Packard Plug Wires, Heater Hose, White Striped Vacuum Hose... Danny
Logged
dannystarr
Hero Member
Reply #646 on:
December 23, 2014, 09:46:38 AM »
Wires
Logged
dannystarr
Hero Member
Reply #647 on:
December 23, 2014, 09:47:19 AM »
Arrestor
Logged
Hero Member
Reply #648 on:
December 23, 2014, 06:29:21 PM »
Danny, can you post a picture of what you picked up in wiper arms and blades?
I got mine since we last talked..... You won't believe where I got mine.
Logged
R 68Z build-
http://www.camaros.net/forums/showthread.php?t=182584
dannystarr
Hero Member
Reply #649 on:
December 23, 2014, 07:50:22 PM »
Didn't get the blades yet, but blade holders. And also the arms. Turns out, if these are correct arms... they match the ones I already have. Pictures later. Gotta go finish X-Mas shopping.. And then take the car for a spin!! ... Chick, I just sent you an email with some picture on another subject... D
Logged
Hero Member
Reply #650 on:
December 24, 2014, 02:54:31 AM »
Radiator cap looks like it was left outside right next to your car, a spot on match.
Those plug wires look to good, your going to have to drag them around the block a few times ..
Logged
dannystarr
Hero Member
Reply #651 on:
January 14, 2015, 03:06:32 AM »
Here is the Solenoid bracket installed. Put it right where it looks like it once was. I can see the change in the dirt and rust line
Logged
dannystarr
Hero Member
Reply #652 on:
January 14, 2015, 03:08:16 AM »
more
Logged
dannystarr
Hero Member
Reply #653 on:
January 14, 2015, 03:08:37 AM »
more
Logged
dannystarr
Hero Member
Reply #654 on:
January 14, 2015, 03:09:06 AM »
more
Logged
Hero Member
owner since 4-Apr-1976
Reply #655 on:
January 14, 2015, 03:56:53 AM »
so what is the purpose of that second circular 'loop' in the bracket??
Logged
72 El Camino, '55-'56-'57 Nomads, '55-'57 B/A Sedan
CRG Member
Reply #656 on:
January 14, 2015, 04:10:33 AM »
Probably to rest against the starter housing and keep the bracket from being able to rotate, which would pull on the wiring.
Logged
dannystarr
Hero Member
Reply #657 on:
January 14, 2015, 07:05:53 AM »
I was wondering that myself. Makes sense to me...
... D
Logged
dannystarr
Hero Member
Reply #658 on:
January 15, 2015, 11:26:03 PM »
Well I got my hot side battery cable mounted. Put that all back together last night. Note the battery hold down with the "K" stamp. The ground cable bolt and washer for the firewall. Soaked all in evaporust over night. That washer sure is special. Would hate to try to find one.... Danny
Logged
dannystarr
Hero Member
Reply #659 on:
January 15, 2015, 11:27:08 PM »
washer again and bolt with embossed "D"... D
Logged
Print
Pages:
1
42
43
44
45
46
57
« previous
next »
General Discussion
