Author Topic: My New '68 Camaro Z/28 Butternut Yellow  (Read 368984 times)
Re: My New '68 Camaro Z/28 Butternut Yellow
« Reply #165 on: July 22, 2014, 01:21:04 AM »
very good stuff,sounds trivial ,but could you shoot a close up of a lug nut ? Need to check the outside , thanks. Seem to think I changed a couple years ago for some reason.
dannystarr
« Reply #166 on: July 22, 2014, 01:29:22 AM »
Jano,
 Not a problem, going to girlfriends garage tonight to pull the carb for rebuild. I will do it then.....Danny
« Reply #167 on: July 22, 2014, 01:29:31 AM »
Here's one of my rims Danny...I'll shoot you number's off my Z for comparison if you want, let me know . When you get to your seat belts and carpet let me know--steve.
dannystarr
« Reply #168 on: July 22, 2014, 01:31:58 AM »
Here is alt brackets with "GT" stamping. Oddly the black bracket is stamped beautiful and deep. The red bracket is only stamped with a "T".    No G, at least any "G" that I could see. Was this common?? ... Danny
dannystarr
« Reply #169 on: July 22, 2014, 01:36:19 AM »
Red Bracket ... Danny
dannystarr
« Reply #170 on: July 22, 2014, 01:37:28 AM »
Red Bracket with only a "T"... Danny
dannystarr
« Reply #171 on: July 22, 2014, 01:38:52 AM »
Was able to get a picture of the lower pulley while changing water pump.   3858533  BJ    GM  or is that a 5 ??  What does the BJ stand for ??... Danny
        S
dannystarr
« Reply #172 on: July 22, 2014, 01:44:39 AM »
Front of engine while cleaning and changing water pump... Yes, I see the wrong clamps on bypass and heater hose... Danny
dannystarr
« Reply #173 on: July 22, 2014, 01:46:33 AM »
center of front engine... Danny
dannystarr
« Reply #174 on: July 22, 2014, 01:50:05 AM »
Body Panel Numbers I have found.
            Misc.. Stamped Body Panel Numbers
                     Hood Left Rear Edge – 20
                                            Fenders – 20
              Header Panel Top of Cowl – 20
                        Left Quarter Panel – H21
                   Underside of Deck Lid – T20
« Reply #175 on: July 22, 2014, 04:27:37 AM »
Hi Danny and great find! What a girl friend! Just got back from vacation this morning and thanks for the email and kudos on my build thread, and yes, we now have Camaro relatives, huh! Great pictures and documentation so thank you! On the GT stamp, know I have not observed enough to have any idea if having the T only was common as many things could have been possible but we now know of one, yours. Hard to find examples like this with so much of the original content still there. I would tend to believe the PCV has been changed due to being a later design but maybe an expert will chime in. Again, great 68Z and congratulations.
dannystarr
« Reply #176 on: July 22, 2014, 09:11:32 AM »
Jano, Here is a couple shots of the lugnut... Danny
« Reply #177 on: July 22, 2014, 10:45:49 AM »
thanks , thread one has to check a few times a day....or your missing out :)
« Reply #178 on: July 22, 2014, 12:59:04 PM »
        S
I'm not sure what the BJ stands for, but most if not all pulley PN's have a 2 letter code after the PN...
Your crank pulley is correct for your Z28...     .. complete pulley list From the CRG information.... :)
http://www.camaros.org/pdf/pulleys-68-2007-02-01.pdf
Z/28 (w/smog)                     Base                  N-40
Crank pulley                     3858533              3858533
Crank pulley extension            N/A                3916385
Water Pump pulley             3770245             3770245
Alternator pulley                 1970831             1970831
Smog Pump pulley              3925522             3925522
Power Steering pulley              N/A                3873847
« Reply #179 on: July 22, 2014, 01:31:34 PM »
mine Dan
