Author Topic: My New '68 Camaro Z/28 Butternut Yellow  (Read 527553 times)
MO
Re: My New '68 Camaro Z/28 Butternut Yellow
« Reply #30 on: July 18, 2014, 04:23:55 AM »
Make sure you tell her she's the star of this thread.
dannystarr
« Reply #31 on: July 18, 2014, 07:21:11 AM »
Hey Vince, I seen that also. It actually looks like the bottom of another E to me. But you are right, it could be a baby C. I can tell you it doesn't have the bottom drain plug, so I think it's an M-20? I will post the other trans pic's. I am hoping all of you experts chime in and keep chiming in to tell me the stamps, and numbers look good. I spent a lot of time collecting data.... Danny
dannystarr
« Reply #32 on: July 18, 2014, 07:27:26 AM »
Both heads dated May 6th '68
dannystarr
« Reply #33 on: July 18, 2014, 07:36:51 AM »
Cowl Tag info
O5E
68-12437      NOR    145458     BODY
TR - 712               YY                PAINT
O5E = 5th Week of May
68 -12437 = 1968 Camaro Coupe
NOR = Body Assembly Plant - Norwood Ohio
145458 = Fisher Body Unit Number
TR -712 = Black Standard Bucket Seats Interior
YY = Butternut Yellow Paint – Lower/Upper No Vinyl Top
Protection Plan Booklet Info
     E        YY       124378N445453   H
     VO523MO   BU0524G               6
     P8E29           2   63
Note: POP shows rear axle code      BU0524G
Actual rear axle stamping in car is   BUO525G
Was this a common mistake to be a day or so off in either direction? Especially with SO MANY 4’s & 5’s in the VIN? Could this be a good thing to show some human error?
Engine Front Pad Assembly Date/Plant/Suffix Code VIN
V0523MO
V = Flint Michigan
05 = Numeric Month of the Year - May
23 = Numeric Day of the Month 23rd - Thursday
MO = Suffix Code – Z/28   4-speed Transmission
18N445453 – Partial VIN
Rear Axle Assembly Stamp / Casting Number
BU 0525 G2
        E
BU = Rear Axle Ratio Code - 3:73
25 = Numeric Day of the Month - 25th Day - Saturday
G = Gear Axle Plant - Detroit
2 = Shift Code – Second Shift
E = Positraction Manufacturer Code – Eaton Company
Casting # 3894860
= 12 Bolt Rear End
Rear Axle #’s / Casting Date
E208
E = Month of the Year – May
20 = Numeric Day of the Month – 20th Day
8 = Last Digit of Year 1968
= Monday May 20th 1968
« Last Edit: July 18, 2014, 08:26:01 AM by dannystarr »
dannystarr
« Reply #34 on: July 18, 2014, 07:42:42 AM »
Cowl Tag rivet backs...
dannystarr
« Reply #35 on: July 18, 2014, 07:44:17 AM »
Block Casting Date...
Block Casting Date = E218
E = Month of the Year - May
21 = Numeric Day of the Month - 21st. Day
 8 = Year - 1968
 = Tuesday May 21st. 1968
« Last Edit: July 18, 2014, 08:01:39 AM by dannystarr »
dannystarr
« Reply #36 on: July 18, 2014, 07:47:24 AM »
Rear Axle #'s...
« Last Edit: July 18, 2014, 08:29:00 AM by dannystarr »
dannystarr
« Reply #37 on: July 18, 2014, 07:54:27 AM »
Trans Side cover...and ID Part Number Tag
dannystarr
« Reply #38 on: July 18, 2014, 07:59:17 AM »
Block numbers above oil filter, embossed in block.   944  657  78N    What are these??
dannystarr
« Reply #39 on: July 18, 2014, 08:32:24 AM »
Maybe it will look like one of these some day...
ZLP955
« Reply #40 on: July 18, 2014, 11:04:27 AM »
Great car Danny, very pleased you got it! And if I were you, I'd put a ring on your girl's finger, she deserves it.
Tim in Australia.
« Reply #41 on: July 18, 2014, 12:16:51 PM »
1968 Muncies that have that little 'c' after the code doesn't mean they are an M22... It's probably an M20... as you said.
Danny, you're doing a great job of documenting the stampings, codes, and numbers for your car..  I suggest you make a digital document (and preserve it) for all the data you are collecting.   That will go great with the car...  :)
« Reply #42 on: July 18, 2014, 01:51:32 PM »
<< Block numbers above oil filter, embossed in block.   944  657  78N    What are these?? >>
Those are foundry pattern numbers - in case there was a problem with the casting, they knew which pattern made the mold the block was cast from.
dannystarr
« Reply #43 on: July 18, 2014, 03:28:05 PM »
Gary thanx, I have ALOT more info. I will slowly get it posted. It's fun, especially when it is correct and matching of course. I am trying to do a nice clean clear picture taking job of it all.
JohnZ, Can you tell me what these frame numbers are? The are on the outside right frame rail in the wheel well. Can't quite read it all, but you can see the 68. I am surprised they are still there.
dannystarr
« Reply #44 on: July 18, 2014, 03:32:49 PM »
Motor Pics...
