I am re-installing the mounting clips into my '68 lower windshield molding after having had all my moldings polished and the clips glass bead blasted and painted. These are the eight major clips plus the two clips that go on each end. I am very suprised by how loose they all fit now. I would have thought they should be pretty snug.
This is the original molding and the original clips that came down the assembly line with the car. It has been a few years since I removed the clips and don't remember how tight they were taking them off........Nothing has changed except for the polishing and bead blasting
The eight major clips are loose enough that if you turn the molding up vertically, the clips will slide right down. The two end clips are loose enough that they can be rocked side to side a little bit while sitting inside the molding.
Should these be this loose or is something wrong here?......And if someting is wrong, how do I fix it?
Thanks.........Dave
