Author Topic: Need pics of 68 RS hidden headlight system  (Read 3537 times)
avnut
« on: May 16, 2014, 01:36:49 AM »
My car is a RS/SS,but when I purchased car back in 77 the hidden light system was removed.I have purchased new repro headlight door assemblys,vac tank etc. but I have no idea where they locate.
If someone here could post a few pics of the mounting locations for the actuators,tank and valve,door stops etc it would be much appreciated.No rush as it will be awhile before I get to the front end.
aka-Tom
68 RS/SS 396 04C Norwood Blue/Blue
427/M21/3.73 12 Bolt posi
Power drum,Std int,D55 console w/gauges,U73 rear antenna. PP code 12 bolt rear axle.
HawkX66
Re: Need pics of 68 RS hidden headlight system
« Reply #1 on: May 16, 2014, 04:00:02 AM »
If you do a search over at camaros.net you'll find a whole lot of posts on this subject. You should be able to find what you're looking for. Good luck.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
avnut
« Reply #2 on: May 16, 2014, 09:48:06 AM »
Will give it a try.Thanks
aka-Tom
Steve68
« Reply #3 on: May 16, 2014, 02:26:14 PM »
Do you have the factory assembly manual?  If so see page 427 through 437 or UPC Z22 pages.  Everything you would need to know to install is there.
avnut
« Reply #4 on: May 16, 2014, 10:13:44 PM »
I have a copy on the way.
aka-Tom
