vaccum hose connection
JohnZ:
--- Quote from: L78 steve on August 11, 2014, 05:07:33 PM ---So is the EGR hose holder clip only on big block?
--- End quote ---
No 1st-Gen Camaro had EGR, but the L-78 had a clip for the PCV hose that mounted under the right front carb nut.
L78 steve:
Yes PVC, Thanks for the correction.
luv2sixty9:
[/quote]
John,
Did the PVC Hose bracket come on a 69 Z28 also.
JohnZ:
--- Quote from: luv2sixty9 on August 21, 2014, 12:36:53 PM ---
--- End quote ---
John,
[/quote]
Nope - it was only used on the L-78.
Pacecar:
Assembly manual shows it for the L78. Bracket is mounted to the valve cover to hold the tube
Navigation
[0] Message Index
[#] Next page
[*] Previous page
