Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Brake pedal swap
« previous
next »
Print
Pages: [
1
Author
Topic: Brake pedal swap (Read 3087 times)
hotrod68
Hero Member
almost finished
Brake pedal swap
on:
April 02, 2014, 07:31:23 AM »
Hey guys. I need to swap a manual transmission brake pedal/clutch pedal setup for a single automatic brake pedal on a '68. I have the automatic pedal and pivot pin to make the change. I also have the cover for the firewall where the clutch pedal rod goes through. Will the automatic pedal simply replace the other pedals with no other parts? It looks as if the other assembly will just drop out when I take everything loose and remove the pivot pin, and the automatic pedal will fit right back in. But before I take the dash apart I don't want any surprises. The car has manual drum brakes if that makes any difference. Any advice would be greatly appreciated. Thanks!
Tweet
Logged
HotRod'68 1968 SS350 coupe undergoing frame-off resto/rod. 386/350/4.11s
Butternut Yellow black standard interior
Hero Member
Re: Brake pedal swap
Reply #1 on:
April 02, 2014, 02:25:28 PM »
Do you have this part?
http://www.rickscamaros.com/camaro-brake-pedal-pivot-shaft-for-cars-with-automatic-transmission-1967-1969.html
Logged
sdkar
Hero Member
Reply #2 on:
April 03, 2014, 02:09:29 AM »
It should be easy and just hook up in there with the existing parts and the new pedal. If you need any of the parts to do this, let me know, as I removed my automatic brake pedal and installed a clutch one.
Logged
hotrod68
Hero Member
almost finished
Reply #3 on:
April 03, 2014, 02:30:11 PM »
Yes, 68Z--that is the pivot pin I mentioned. The pedal and pivot shaft/pin are new from Rick's, just as in the picture you posted. Thanks fellows. You guys rock.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
Brake pedal swap
