Author Topic: Block crayon marks  (Read 11094 times)
BillOhio
    • photobucket
Block crayon marks
« on: March 28, 2014, 12:53:35 AM »
Anyone want to take a guess what this was?
Drivers side front cylinder. Pan rail is at bottom
1968 RS 327 4 speed
Mark
Re: Block crayon marks
« Reply #1 on: March 28, 2014, 01:44:36 PM »
CK?
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
BillOhio
    • photobucket
« Reply #2 on: March 28, 2014, 05:25:35 PM »
I thought OK but weird its there
1968 RS 327 4 speed
« Reply #3 on: March 28, 2014, 09:03:43 PM »
I have seen DZ and 302 on the block sides in the past.
rszmjt
« Reply #4 on: March 29, 2014, 05:10:45 AM »
I have a 6,000 mile 70 Z28 engine and CTB can clearly be seen both sides of the block . I too have seen DZ on 302.
Mark
« Reply #5 on: March 29, 2014, 12:18:48 PM »
Well theres no CK engine suffix for a chevy engine, could be a CR which is a 1958 Corvette 283, or maybe it is an OK.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #6 on: March 29, 2014, 12:22:33 PM »
 My vote is with 'OK'
It's good to see these marking were done while the engine was assembled and prior to painting over them and surviving today.
« Reply #7 on: March 29, 2014, 03:17:46 PM »
All engines had what would ultimately become the stamp pad suffix scrawled on the side of the block in grease pencil; that was done in the first operation on the engine assembly line, where the block was upside-down and the bores were air-gaged. That marking told everyone on the line what innards and external parts to install in the block (cam, crank, rods, pistons, oil pump and pickup, pan, balancer, lifters, heads, intake, water pump, valve covers, distributor, etc.). The pad didn't get stamped until the engine was turned right-side-up and the heads went on.
« Reply #8 on: March 29, 2014, 03:28:56 PM »
Hi John,
  I thought the engine prefix stamp was applied before the heads were mounted which explained why some of the stampings were close to the head to deck edge or under the water plug protrusion as with BB's. Or was it different between BB and SB in regards to when the pad was stamped in relation to the head mountings?
BillOhio
    • photobucket
« Reply #9 on: March 29, 2014, 03:59:42 PM »
This was on head. Same cylinder
1968 RS 327 4 speed
« Reply #10 on: March 29, 2014, 06:51:54 PM »
Here is the engine out of the blue 69 Z I recently restored.
Hi John,
Yes, BB were stamped without heads installed, SB with the heads installed
ZLP955
« Reply #11 on: March 29, 2014, 10:07:11 PM »
Interesting! I was cleaning up a Flint CE block recently and noticed yellow grease pencil marks on one side (which I have left undisturbed); Would the same process as JohnZ described have applied equally to a CE assembly as a production engine?
Tim in Australia.
BillOhio
    • photobucket
« Reply #12 on: March 29, 2014, 11:49:01 PM »
Mine looked to be yellow but I do wonder if they were white that aged?
1968 RS 327 4 speed
« Reply #13 on: March 31, 2014, 04:22:01 PM »
Hi John,
On small-blocks, the machine code stamp was done after the heads went on; on big-blocks, the machine code stamp was done BEFORE the heads went on so the stamp could be done on the outboard end of the pad without having the big threaded plug in the head in the way of the gang-holder. Big-blocks had to be done that way so the car assembly plants could stamp the VIN derivative on the INBOARD end of the pad, where there was no plug in the way of the stamp.
« Reply #14 on: March 31, 2014, 04:28:57 PM »
Yes - the only difference was that a "CE" engine was a short-block, so it didn't get heads, an intake, a water pump, distributor, or an oil pan. This made them difficult to handle (had to be done manually with hi-lo's and wooden pallets when they got to the end of the line), so they were usually run on weekends.
