Poll
Transmission Decode Help
197201365 Trans #
0 (0%)
Cast #9052 GM NFC2
0 (0%)
Total Members Voted: 0
Author Topic: Cast Iron Transmission  (Read 9818 times)
Bigbmckune
« on: September 26, 2006, 07:07:41 PM »
I need more info, I have a 67 special ordered coupe, 327/275hp 4 speed, all matchng #s however the trans seems to be out of place? It is cast Iron, with a number of 197201365 Cast #9052 GM NFC2 Any help on this one? The car was built in Van Nuys
hotrod68
  • almost finished
Re: Cast Iron Transmission
« Reply #1 on: September 27, 2006, 03:47:33 AM »
I'd think a 275hp car sould have a Muncie, but I'm no numbers guru. Somebody will know! Good luck.
« Reply #2 on: September 27, 2006, 04:18:52 AM »
Well Bigb, those numbers don't seem to correspond to anything I can find, but if it's a Saginaw 4 speed transmission, it would be "correct" for your car. For 1967, the only Camaro's that came with a Muncie 4 speed would be the 350 and 396 engines. All 327's came with a Saginaw (if ordered with a 4 speed). Are there any other numbers cast into the transmission?
RAfbody
« Reply #3 on: September 27, 2006, 02:04:17 PM »
A Z/28 had a muncie in 1967 as well.
Russ
Bigbmckune
« Reply #4 on: September 27, 2006, 03:35:52 PM »
Thanks guys, I will be checking, I believe we may have looked at the rong side. We have the original invoice that shows the original owner paid $142.00 for a 4speed. I will let you know what i find!  :o
lakeholme
  • 68-12D L30/M35
« Reply #5 on: September 28, 2006, 05:56:38 PM »
Look on pages 280 and following of Colvins, BY THE NUMBERS, 65-69, when you do find the numbers. Ed is right.  It should be a cast iron Saginaw in a 327/275.  But the numbers you gave aren't...
« Last Edit: September 28, 2006, 05:59:08 PM by lakeholme »
KevinK
    • Hudson Valley Camaro
« Reply #6 on: October 03, 2006, 06:56:32 PM »
...If it helps, ...here are some photos of the numbers I got off a '67 (L30/M20) I had:
  Here's a link to the full webshots album:    http://rides.webshots.com/album/254439242GomVOm?start=12
  ...Here's a photo of the numbers on the trans (drive's side)  http://rides.webshots.com/photo/1254455252063892652MUDLqj
