Author Topic: My 69 SS/RS Project started  (Read 34769 times)
sul423
Re: My 69 SS/RS Project started
« Reply #30 on: March 21, 2014, 06:59:20 PM »
the trim tag
Lets see some stuff that I need to repair.
Corroded roof panel
68 Camaro Dashboard!!?? (were made by previous owner)
Also, bad interior condition.
Under hood condition and 454 engine.
Azure1969Z/28
« Reply #31 on: March 21, 2014, 09:03:11 PM »
That sure looks like a 69 Firebird interior (dash, steering wheel etc) Maybe it morphed into a Camaro ???
« Reply #32 on: March 21, 2014, 10:16:46 PM »
Nope, it started out as a Camaro if the VIN is correct... 124379N544009
Azure1969Z/28
« Reply #33 on: March 21, 2014, 10:59:08 PM »
IF
« Reply #34 on: March 21, 2014, 11:11:11 PM »
 that dash area doesn't look quite right, maybe modified? Pretty interesting to see someone move the battery tray to the firewall. I have seen it relocated to the trunk, but first time seeing someone relocate to the firewall.
69Z28
  • 69 X33D80 Z28
« Reply #35 on: March 21, 2014, 11:15:03 PM »
Interesting...Looks more like a 67 Camaro/Firebird dash panel. Needs some forensic work done to determine what year it is. TT indicates a very early built 69 and if it is, what happened to the original dash panel? Do we have a mystery on our hands? I'm intrigued.
GaryC
« Reply #36 on: March 21, 2014, 11:25:40 PM »
The switches correspond more to a 69 firebird dash, but the 4 hole assembly in the middle doesn't ... is that for gauges, or AC?
Azure1969Z/28
« Reply #37 on: March 22, 2014, 03:57:50 AM »
Are those pop rivets holding the cowl tag on ???
« Reply #38 on: March 22, 2014, 04:06:28 AM »
Yup...
Fahad, was the cowl tag like that when you purchased the vehicle?
Yes it is.
Azure1969Z/28
« Reply #39 on: March 22, 2014, 04:10:37 AM »
Firebird
69Z28
  • 69 X33D80 Z28
« Reply #40 on: March 22, 2014, 04:41:46 AM »
I found this pic of a 69 TA dash.
GaryC
« Reply #41 on: March 22, 2014, 04:49:45 AM »
Fahad, could you take some more close up or detailed pictures of the dash and the VIN (serial) number?
James to strangers, Bentley to friends
1969 SS/RS 396 coupe Hugger Orange X22 712 bought in 79
1969 SS 350 coupe LeMans Blue 713 bought in 79
1969 307 4spd. coupe Daytona Yellow 711 bought in 85
« Reply #42 on: March 22, 2014, 04:50:45 AM »
firebird, and then quarters and tail panel swapped out? Possibly, or someone swapped out the dash.
Hey Fahad how about a pic of the Vin stamp on the top of the cowl? or about where your battery tray is on the firewall?
« Reply #43 on: March 22, 2014, 04:52:07 AM »
"I found this pic of a 69 TA dash."
I saw those as well, seems like they all have those vents in the dash, and his doesn't  have those, but has the 4 holes in the center.
69Z28
  • 69 X33D80 Z28
« Reply #44 on: March 22, 2014, 05:33:20 AM »
Very unusual car Fahad has. I am so curious what he actually has, a Camaro or a Firebird. There are really only a few things that would confirm it either way isn't there? As already said, a replacement dash (fiberglass?) which does appear to be a 69 Firebird without the a.c./astro vents in the corners and the added 4 center holes and the dash pad looks more 67 with no drop down legs. Then all the Camaro body panels on it if it is a Firebird.  Would explain the 67-68 vinyl top trim too,but I understand that some installers used those even on some 69's. Here'a pic of a 69 Penske car with an added vinyl roof cover, unless that is really a modified 67-68 body.
GaryC
