Author Topic: 68 camaro convert upper windshield molding removeable  (Read 6081 times)
dmchrist
« on: November 10, 2005, 04:06:06 PM »
I can't seem to get the molding off without bending it. Is there a secret way to get it off?
68rsssrag
Re: 68 camaro convert upper windshield molding removeable
« Reply #1 on: November 11, 2005, 05:35:47 AM »
Which moulding are you talking about? If it is the large 2 pc at the top, Remove the mirror and its mount first. Then use rubber gloves for a grip and grab it on the outside while standind inside and give it a twist while pulling up and to the inside. It will be help my body caulk but once the bond breaks it should pop off the front.
Arno
