Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Fake 67 Pacecar on Ebay
« previous
next »
Print
Pages: [
1
Author
Topic: Fake 67 Pacecar on Ebay (Read 4651 times)
Mark
CRG Member
on:
October 07, 2013, 11:07:44 PM »
http://www.ebay.com/itm/181233448098?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D181233448098%26_rdc%3D1
All made up to look like a Pacecar. Has a posted vin of 124667N155815 and a cowl tag of 05B, body number 158332. He actually calls it a Pacesetter car, apparently not knowing exactly what the pacesetter program was.
7N155815 is a December of 66 VIN, and a body number of 158332 is beyond the end of 67 Camaro production at Norwood.
Tweet
Logged
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Hero Member
Re: Fake 67 Pacecar on Ebay
Reply #1 on:
October 07, 2013, 11:35:12 PM »
Interesting tag. Option 1 position (W) and interior color code look to be misplaced.
My 67 conv is a 5B period and the VIN and body date and number is nowhere this one.
The seller does have an interesting article and I assume he is making it sound that this is a dealer car made to look like a Pace Car. Even so, that still wouldn't support the differences in the period mismatches of VIN tag info. if a dealer bought a non pacer.
Logged
Mark
CRG Member
Reply #2 on:
October 07, 2013, 11:46:02 PM »
Tags a repro, if the VIN on the dash matches whats on the car, none of the drivetrain is original as there were no BB's in December of 66 and all the parts in the car are based on the fake cowl tag build date of 05B.
Logged
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Hero Member
Reply #3 on:
October 08, 2013, 01:41:49 AM »
The engine pad is definitely not kosher
Not to be picky ( well maybe ) but he did say it can be a museum piece?
He makes it a point to stress how correct the car is and yet the engine ground is in the wrong place.
The TH400 pan looks to be wrong.
The rear antenna looks to have more pitch than usual. I suspect an incorrect base?
The trim tag is missing the rear antenna code
Spring/shock perch retaining bolts too long
The traction bar axle housing bracket is missing a hole above the mounting bolt. Not sure why. I looked at my 4B w/TH400 w/axle date 0404 and round bar and it has the extra hole in the bracket.
Looks like wrong oil dip stick style
looks like incorrect accelerator rod for that period
do I see spark plug shields?
missing PCV hose support bracket
water temp sending unit wire looks like it's in the wrong position
Wasn't there a break in the stripe by SS?
worm clamp on heater hose on engine side
missing vacuum advance tube
wrong valve covers...missing wire tower on left side and temp gauge wire hold downs
looks like a broken rear cover bolt
single piston disc brakes
where's the brake metering valve?
PB booster looks like a repro
non painted intake manifold bolts
clutch fan
And there are 5 bids for this?
That's enough for me tonight!
Logged
x77-69z28
Hero Member
Reply #4 on:
October 08, 2013, 02:13:41 AM »
Worst restamp of a block that I have seen in some time.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
