Author Topic: 67 camaro vin location  (Read 19469 times)
Jbyer8
« on: October 02, 2013, 08:16:11 PM »
Looking at buying a camaro where the vin is riveted to the left of the master cylinder. I thought 67's had the vin on driver side door frame.
Jbyer8
Re: 67 camaro vin location
« Reply #1 on: October 02, 2013, 08:20:02 PM »
Here is a pic.
Jbyer8
« Reply #2 on: October 02, 2013, 08:22:49 PM »
Better pic
vtfb68
« Reply #3 on: October 02, 2013, 09:31:22 PM »
JB,
  That is the trim tag location, however that is not a trim tag from a domestic 67 (just looks like a piece of metal punched with the some numbers,  124377 is all I can see) Check this site for '67 trim tag pictures and hidden VIN #'s.
  The car seems to be monkeyed with. Be carful before you lay out any money. and yes, '67 VIN's should be on the door jam. Any better pictures?
68 08E LA RS Y2 749 L30 M35
Jbyer8
« Reply #4 on: October 02, 2013, 09:39:27 PM »
This is only other pic I got. He has title which shows vin of 124377N166208.
I'm just concerned why it's there instead of cowl tag.
Petes L48
« Reply #5 on: October 02, 2013, 10:06:12 PM »
VIN should be stamped on a plate riveted to the drive side, front door jamb area, near the interior light switch.  There are also hidden partial VINs under the cowl vent panel and on the firewall, under the heater box.  As stated that trim tag looks home-made unless it's some sort of foreign tag.  Still looks bogus, picture is not too clear.  Be careful.
« Reply #6 on: October 03, 2013, 03:00:01 PM »
If the car doesn't have the correct stainless steel VIN plate rosette-riveted to the driver's side door opening jamb that matches the title, pass on it. That thing on the firewall isn't a VIN plate, and also isn't a cowl tag - it' some kind of home-made thing.
lakeholme
  • 68-12D L30/M35
« Reply #7 on: October 03, 2013, 06:21:10 PM »
X2 to what JohnZ and others have said...
You do mention that the seller has a title and the VIN matches what's on that fake tag, but....
Take a look HERE at this information from the Department of Justice.
« Reply #8 on: October 04, 2013, 02:27:45 AM »
Can you look on top of the cowl for the VIN stamped under the cowl grille ? That might clear the air a bit, but it could be difficult to get the owner to let you remove it. It doesn't look like a State plate, which would be affixed on the car if it was stolen/recovered/resold (usually has the State Of ______ stamped or headed on it). I've seen that done before, but look for the hidden VIN numbers if you can. Does look extremely bogus -
« Reply #9 on: October 04, 2013, 02:33:55 AM »
For curiousity's sake, it would be interesting to see the *real* VIN, but regardless of what it was, there's NO way I'd purchase such a vehicle....
69Z28
  • 69 X33D80 Z28
« Reply #10 on: October 04, 2013, 08:53:32 PM »
Could be a state issued tag. Where is the car? Maybe you need to contact your local DMV to get more info on it. Car could have been slammed into where the original tag was or the car may have been in a salvage yard and returned to service. Lots of things to consider.
GaryC
« Reply #11 on: October 05, 2013, 03:48:00 AM »
As someone posted earlier, every state issued VIN I've ever seen was identified as such...
JKZ27
« Reply #12 on: October 17, 2013, 02:20:51 AM »
Also, I don't think a state issued VIN resembles a cars original VIN in any way. Usually just a pre-stamped plate with with a number and state logo. Same type of plate that would go on a home made trailer, at least in Maryland.
John
John
68 RS Ash/Ivy Gold 327EFI M20
elcamino72
    • More Information on Camaro Fraud
« Reply #13 on: October 18, 2013, 03:47:47 PM »
Actually in several states if the original VIN is known it can be used, with exceptions, in the state issued VIN plate.  I think the first order of business is to remove the paint from the plate and find the hidden VINs.  Until these issues are sorted out, I would stay away.
67rs/ss350 68z/28
« Reply #14 on: October 18, 2013, 08:40:20 PM »
If you google the vin number you can see the car when it was blue, with different tires and wheels. Same tinted windows and engine compartment with the 427 in it.
Luwi67
« Reply #15 on: November 18, 2013, 06:19:01 PM »
This is a state issued VIN tag, using the correct VIN that matches both hidden VINs and, it is in the same location as the original VIN tag on the door jamb:
