Author Topic: Reading The Body Broadcast Copy...Here's the codes I have  (Read 4953 times)
GS STAGE 1
« on: September 04, 2006, 03:45:19 PM »
I know I'm asking alot, but can anyone help decode these codes/#'s that are actually visible
I took my BBC out in the sun, only way I could decipher the codes, with the help of a magnifying glass
Production Date 11 29
Sequence # 979
Serial # 510_ _ _ The last 3 numbers are actually stamped on the block in the rough area, not stamped on the pad
Box
7) C
8) C
9) B
10) ?
11) A
12) A
13) #...it appears to be the # only....?
14) D
28) AD
52) TM
56) CU
59) EA
61) TI
63) AG
66) CT
67) Its a Q or Zero
75) Z
76) P
77) 1
79) A
86) CI
89) R 59, Im assuming this is battery
92) 2
94) A
96) VY
99) L
103) XA
104) H
116) CE
119) G, maybe a C
121) ZC
123) JR
125) SM
127) ? CR
129) ? G
131) 65
133) XE
135) 5
137) E78_14 its torn, Im assuming E78X14 tires, then its says 42.B
Order ?) MJD 883
Order Recieved) 10/31
« Last Edit: September 06, 2006, 06:10:12 PM by GS STAGE 1 »
GS STAGE 1
Re: Reading The Body Broadcast Copy...Here's the codes I have
« Reply #1 on: September 05, 2006, 09:34:13 PM »
Someone please tell me where I can find this info, I've done a search of build sheets, with no help for info. Is this secret info?
fiveforty
« Reply #2 on: September 05, 2006, 11:05:32 PM »
On page 85 of Jerry Macneishs 69 Camaro book there is a copy of a Body broadcast sheet. At least you will be able to tell what your Letters and #s relate to.
GS STAGE 1
« Reply #3 on: September 06, 2006, 02:15:38 AM »
Thank you so much fiveforty :)
You saved me alot of questions here ;D
« Last Edit: September 06, 2006, 02:18:56 AM by GS STAGE 1 »
