Author Topic: 327 Timing Chain Cover  (Read 5175 times)
67rs327
« on: September 06, 2013, 02:26:49 AM »
Looking to replace the timing chain cover on my '67 327/275 as I just discovered while cleaning it has developed some pin holes & is weeping oil. Bone stock orig.  engine & I'm a little confused when looking for a replacement - what I specifically need in regards to the right size? (7",8",short,deep, etc., etc.). Also - what vendor carries the best  OEM type part? No chrome! Looking for basic painted cover. Thanks
1967rs L30/M20 Bolero Red - LOS 11A.
Chris - New Hampshire.
Everett#2390
  • ^Bess
Re: 327 Timing Chain Cover
« Reply #1 on: September 06, 2013, 03:27:40 PM »
I believe you will need the one style with the welded on scale as opposed to the bolt-on scale.
A flashlight is a case for dead batteries.
1968 Z28
« Reply #2 on: September 06, 2013, 05:13:38 PM »
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
67rs327
« Reply #3 on: September 08, 2013, 11:54:33 PM »
That works! Thanks man.
« Reply #4 on: September 30, 2013, 05:05:34 PM »
Depends on where the holes are, but I'd weld or braze the holes closed and use the original part.
« Reply #5 on: September 30, 2013, 05:53:36 PM »
I agree with Kurt...   repair rather than replace whenever possible..  :)
67rs327
« Reply #6 on: October 01, 2013, 01:56:36 AM »
Got it. Coming off this weekend and will inspect to see what I can do to keep the orig. unit - Thanks
