Author Topic: How to adjust 69 RS head light doors?  (Read 4104 times)
« on: September 02, 2006, 11:33:01 PM »
The headlight doors on my 69 are in need of adjustment from rubbing on the lower outer housing.  Can anyone tell me how to make these adjustments?
69 Camaro Z10
72 GMC C1500
79 Mazda RX7
04 Mazda RX8
06 Corvette Z06
10 BMW 650i
  • LF7/M35/Z22/Z87
Re: How to adjust 69 RS head light doors?
« Reply #1 on: September 03, 2006, 04:57:27 AM »
Assuming that the entire hide away headlight housing itself is sitting correctly (all bushings in place, etc), the painted part of the outer door can be adjusted, slightly, by loosening the two screws shown in the pics.  Allows some freedom to align the door with the fender and valance cutouts - and prevent rubbing.
If it is rubbing "hard", check to be sure that all of the bushings are in place on the main shaft of the door assembly.  They are simply plastic items and can wear through and fall out.  When I went through my headlignts a year ago, the bottom bushings on both sides were completely gone.  Mine weren't rubbing, but were, at times hard to open or close.
« Last Edit: September 03, 2006, 08:09:53 PM by rich69rs »
Richard Thomas
1969 RS
  • 1st and 5th Gen Camaros
« Reply #2 on: November 08, 2006, 01:52:12 AM »
Just saw this post. I have the same problem with my '69. The mechanism is sagging significantly and it's very hard to open and close the doors. Someone pointed out to me the headlight mechanism support brace. See 1969 Factory Assembly Instruction Manual UPC Z22 A2, Item 3. If this brace is missing or bent, the entire mechanism will sag.
When you solve the problem, I'd be interested in what you did.
Also, it looks like we have the same color scheme, Dover White with Hugger Orange stripes?
1969 Camaro Z/28 RS
Numbers Matching
