Author Topic: Replace Powerglide with a 4 speed Muncie  (Read 12349 times)
dellswo
« on: August 30, 2006, 04:23:54 PM »
1967 Camaro 327 with a Powerglide. I am switching over to a Muncie 4 speed and I do not see a place to attach the clutch return spring. A big block has a metal bracket you attach to the exhaust manifold. Where do you attach the clutch spring to on a small block?? I have a rod that connects to the clutch fork and the other end of the rod connects to a spring. The spring has to hook on something but I cannot figure out what ... Help ??? I don't want to drill a hole in the engine mount ... What did the spring attach to from the factory ??
L6Ragtop
Re: Replace Powerglide with a 4 speed Muncie
« Reply #1 on: August 31, 2006, 02:49:50 AM »
There should be a small hole (for the spring) in the engine mounting bracket.
Dan
dellswo
« Reply #2 on: September 03, 2006, 07:20:58 PM »
Is the engine mounting bracket also called the motor mount ?? I checked that and there are no holes on either mount ( passenger or drivers side) . If I have to
I can drill a small hole into the mount for the spring ......
« Reply #3 on: September 04, 2006, 02:10:28 PM »
That's the engine mount frame bracket - look closely and you should see a small hole in the flange that overhangs the rear edge of the crossmember.
dellswo
« Reply #4 on: September 05, 2006, 06:02:44 PM »
Is this the engine bracket ? I do not see a hole on mine ?
dellswo
« Reply #5 on: September 05, 2006, 06:06:29 PM »
or isthis the bracket that should have the hole in it for the spring ??
« Reply #6 on: September 06, 2006, 08:58:06 PM »
The first photo (the frame bracket, not the rubber mount) should have the small hole for the clutch return spring.
VXC961
« Reply #7 on: September 21, 2006, 02:11:24 AM »
I know it's probably not at the top of your list, but if you get a chance could you take some pictures and/or describe how the process went?  I've got a '68 with a powerglide, and I've contemplated the same swap many times.
Thanks, and sorry I didn't have any advice to offer.
OCB
deejaygee
« Reply #8 on: September 21, 2006, 08:27:31 AM »
Here's a photo I found of a clutch return spring on a 67 small block (no, not mine).
69CamaroConv
« Reply #9 on: October 25, 2014, 12:24:18 AM »
I swapped a pg for muncie. I couldnt find any hole for the return spring so i made one lol
