Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
Temperature sensor in engine block
« previous
next »
Print
Pages: [
1
Author
Topic: Temperature sensor in engine block (Read 5187 times)
DonSTP
Member
68-RS
on:
August 30, 2006, 02:49:02 AM »
Curious if anyone's removed the temp sensor in their engine block if they had to drain the coolant from the block first?
Thanks -
Tweet
Logged
CRG Member
Re: Temperature sensor in engine block
Reply #1 on:
August 30, 2006, 04:12:48 PM »
There aren't any temp sensors in the engine block - only in the cylinder head or intake manifold. You need to drain enough coolant to get the level below that of the sensor before removing the sensor or you'll have a real mess to clean up.
Logged
Print
Pages: [
1
« previous
next »
Maintenance
