Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
Car pulls to the right when braking.
« previous
next »
Print
Pages: [
1
Author
Topic: Car pulls to the right when braking. (Read 3228 times)
discobiscuit
Newbie
on:
June 30, 2013, 11:11:50 PM »
I've replaced both front calipers, bled the lines and there are no leaks but when I apply the brakes the car pulls to the right.
Also...I'm unable to get the brakes to firm up. Should I bleed the rear brakes as well?
Thanks in advance for any help.
Tweet
Logged
Hero Member
Re: Car pulls to the right when braking.
Reply #1 on:
July 01, 2013, 12:30:03 AM »
If you didn't replace the rubber lines, do so. They expand from within and is the major cause of pulling.
Logged
NoYenko
Member
Reply #2 on:
July 01, 2013, 02:42:22 AM »
Defiantly replace the brake hoses if they are original and bleed the rears too. You should also check the rear shoe adjustment while you have the wheels off, you may have one rear braking that can contribute to a brake pull. George
Logged
Print
Pages: [
1
« previous
next »
Maintenance
