Author Topic: NOS Idler Arm vs Factory Original  (Read 8137 times)
Edgemontvillage
« on: June 26, 2013, 07:07:13 PM »
I just purchased an NOS idler arm for my '69 Z. I have read there are some differences between the factory originals and NOS service replacements however the part I received was "missing" the cotter pin hole which struck me as a manufacturing defect. I was later told that NOS idler arms used an oval locking nut rather than the common castellated nut and cotter pin combination. Can anyone validate this observation?
WorkinProgress
Re: NOS Idler Arm vs Factory Original
« Reply #1 on: June 28, 2013, 11:43:01 AM »
Takes an 18 mm prevailing torque nut. Uses no cotter pin. Was the last design idler arm. GM part number 14083585 Group 6.895
        - Warren
69Z28freak
« Reply #2 on: June 29, 2013, 04:04:51 AM »
        - Warren
I tested the thread on this idler arm and it is a 12 mm coarse thread.
Mike 1969 Grandma Camaro
ZLP955
« Reply #3 on: June 29, 2013, 06:50:57 AM »
Lloyd does the NOS idler arm have a 'C' or an 'O' stamped in between the 2 frame mounting holes?
Tim in Australia.
Hans L
« Reply #4 on: June 29, 2013, 04:38:47 PM »
Here's a close-up of the idler arm from my Z (04B, Van Nuys Build).   Note hole for cotter pin and "C" stamp.  Car had about 70,000 miles on it, all SoCal.  No reason to believe it or any suspension components were replaced (many still had original factory markings).
'69 Chevelle SS 396 4 Speed
Edgemontvillage
« Reply #5 on: July 01, 2013, 06:18:08 AM »
The NOS arm isn't stamped on either side of the bracket that bolts to the frame.
« Reply #6 on: July 02, 2013, 12:51:15 AM »
Our 68Z has an "O" stamped idler arm.
67rs/ss350 68z/28
« Reply #7 on: July 02, 2013, 01:13:21 PM »
My 04D 68Z has the letter "C" stamped idler arm
1968 Z28
« Reply #8 on: July 02, 2013, 05:57:00 PM »
My 1968, 07C, Z28 has a "C".
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Boston14
« Reply #9 on: July 07, 2013, 12:43:50 PM »
My 1969, 11D (68) SS has a "C".
boston14
1969 SS/RS 350 Convertible
Edgemontvillage
« Reply #10 on: August 01, 2013, 06:46:47 PM »
Thanks for the feedback and photos. Its clear the NOS Idler Arm I located is a later, service replacement and differs somewhat from the factory original.  I located a nice original and installed that instead.
