Author Topic: door mirror adjustments????  (Read 5437 times)
dab67
  • 67 SS
« on: June 17, 2013, 07:18:43 PM »
The door mirror on my 67 will not hold where I place it. Is there a way to tighten the pivot point or ball of the mirror to remedy this problem or do I have to replace the whole unit?
Thanks in advance
Dab67
77thor
Re: door mirror adjustments????
« Reply #1 on: June 17, 2013, 09:56:53 PM »
Common problem with the repro mirrors for all first gen's.
I've heard that some have had luck by removing the mirror glass and tightening something(screws?) behind it...
Glass can be removed by soaking the whole unit overnight in mineral spirits to loosen the glue.
1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B LOS Build
1977 Camaro, 350(LM1), M20, 10 Bolt Posi, Purchased New, (SOLD)
tom
    • Discount Internet Services
« Reply #2 on: June 18, 2013, 06:23:21 AM »
This was discussed at length in another thread. Use the advanced  search for: loose door mirror. Should get you there.
69 X11 Z21 L14 glide
o
lakeholme
  • 68-12D L30/M35
Phillip, HNR-AACA, Senior Master, Team Captain
Spring Southeastern National meet chair, April 6, 2019
Spring Charlotte Autofair, April 4-7, 2019
2019 Glidden Tour Host
dab67
  • 67 SS
« Reply #4 on: June 24, 2013, 06:17:26 PM »
Thanks to all that responded to this question and special thanks to Lakeholme for finding the link that instructs you on how to solve the problem.
Dave
Farm Boy
« Reply #5 on: June 24, 2013, 10:52:27 PM »
I guess you could use the slow messy method in the above link.
What I did was much quicker and easier. I used a small hammer and a sharp punch. I removed the mirror and turned the head to expose the part of the ball that is normally covered. I used the hammer and punch to knurl the ball. I then moved the head some and knurled the other side of the ball. The mirror is nice and tight now and the knurling is hidden when the mirror is returned to its normal position. It is a quick and dirty fix and that works great!
tmodel66
« Reply #6 on: June 25, 2013, 02:41:54 AM »
How did you get the mirror out?
Daniel
77thor
« Reply #7 on: June 25, 2013, 01:28:55 PM »
What he did was take the mirror off the car and punched the ball.
He did not remove the mirror glass.
lakeholme
  • 68-12D L30/M35
« Reply #8 on: June 25, 2013, 07:48:24 PM »
How long since you did it, and how many miles?
Farm Boy
« Reply #9 on: June 26, 2013, 07:03:37 PM »
I has been at least three years since I fixed my mirror, maybe longer. I put around 1500 miles per year on the car. The mirror is still as tight as the day I fixed it. If needed I can still adjust it.
lakeholme
  • 68-12D L30/M35
« Reply #10 on: June 26, 2013, 09:43:05 PM »
Thanks!  Sometime in the "dim, dark" past I heard that fix would not last.  But you've gotten good results...
