Author Topic: Window,glass, weathetstrip  (Read 3222 times)
Rufcar
« on: May 20, 2013, 04:40:54 PM »
Doing assembly of doors, window, weatherstriping. The question is what comes first? I have glss in and adju
sted, so do now install the felts, the quarter window chrome end, tbe stainless top that holds thr door rubber
Whats the play by play process? Tkx jimf
Petes L48
Re: Window,glass, weathetstrip
« Reply #1 on: May 20, 2013, 09:40:50 PM »
The Fisher Body Service Manual is probably a good place to start, downloadable from here:
http://www.camaros.org/forum/index.php?topic=9433.0
Rufcar
« Reply #2 on: May 26, 2013, 10:31:30 PM »
Once I got the glass in and adjusted i looked at the Fisher book and figured the installation was just in the order of there assembly process it took me about 3 hrs per side of car to install everything. Its tight and I gather it will loosen up in the sun and after a bit of time. Dont know if it leakes or not as I wont try water until I finish the front cowl, windshield moldings and grill then the outside will be complete. Then Ill start the Ebrake assembly which is all missing. Tkx
